new colum wiring help
Old Apr 27, 2009 | 02:30 PM
TheWildcat's Avatar
TheWildcat
Default new colum wiring help
I have a later model colum with telscope to put in my 97... the motor has 2 wires... hook it up and it goes 1 way, reverse it goes the other...the tele control switch has 3 wires one common, 1 when pushed up and the other when pushed out... now the question....how can I make this work? thanks John
Old Apr 27, 2009 | 02:51 PM
lucky131969's Avatar
lucky131969
So I take it you are not going to use the LH SCM. If you just want to make the motor drive both directions, you could used 2 DPDT relays actuated by the tele control switch.
Old Apr 27, 2009 | 03:19 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Get the two SPDT relays. Ground on both 87a pins, 12v to both 87 pins and both 85 pins, run your switch common to ground and the other 2 wires to pin 86 (one on each) and your motor wires to pin 30 (one on each) If the motor runs backwards, reverse wires on pin 30 or pin 86. You will be grounding the common wire on your switch and pulsing a ground to the relay. The relays rest at ground and when you activate one, it will go hot while keeping the other at ground. The voltage reverses when you change switch directions.
Old Apr 27, 2009 | 03:53 PM
lucky131969
SPDT is a better way.
Old Apr 27, 2009 | 03:54 PM
TheWildcat's Avatar
TheWildcat
Default ok
ok where do I come up with the relays?
Old Apr 27, 2009 | 04:01 PM
lucky131969
Auto parts store, radio shack, etc.
Old Apr 27, 2009 | 04:31 PM
TheWildcat's Avatar
TheWildcat
Default Thanks
kool deal Ill try to find them thanks John
To new colum wiring help
