Wheel lock shattered (help!)
Old Apr 27, 2009 | 07:11 PM
DNAST1's Avatar
DNAST1
2025 C8 of the Year Finalist - Modified
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
Default Wheel lock shattered (help!)
Hey guys need your help! I was torqing down the wheel lock on one of the front wheels (lock is 6 years old), and it broke into pieces! Now the tapered/cone piece is still on the stud in between the wheel. Please let me know if you have any ideas of how I can get the rest off to get the wheel off! I am going to replace the other locks so this does not happen to me again. Thanks
Old Apr 27, 2009 | 08:33 PM
rbrtclk's Avatar
rbrtclk
A small chisel might work or maybe you could drill it in about 3-4 places and it will fall out.
Old Apr 27, 2009 | 11:36 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I think a smaller socket with the center tapered with a rotary file should work, but if it doesn't, they sell nut-busters at harbor freight.
Old Apr 28, 2009 | 09:20 AM
LDB C5's Avatar
LDB C5
Drill it. You will need to replace the stud though. Start with a bit about 1/3 the diameter of the stud, and drill most of the way through the stud, then change to a bit about the same size, just a little smaller.
Old Apr 28, 2009 | 12:31 PM
DNAST1's Avatar
DNAST1
Thanks for thr replies so far. Still waiting to hear back from McGard tech rep.
Old Apr 28, 2009 | 01:05 PM
timemender's Avatar
timemender
Post the solution when it's all done.
Good luck
Old Apr 28, 2009 | 10:01 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
You can try a chisel, but you will most likely not be able t move it. Plan on destroying the stud in the process. If it busted, it was most likely too hard anyway. This means it will break again, if you hit just the right way. It probably won't do anything though. You said it broke while you were torq'ing - this means it broke on the way in. It is still under pressure so it will be tough to get it out. If you would have been removing it, it would be alot easier to break it and get it off.
Whatever you do, be careful not to damage the tapered counterbore in the wheel itself.
Old Apr 28, 2009 | 10:12 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
What about one of those Gator sockets that mates itself to any size nut or bolt? It just might have enough grip to get it off.
And if it does not work you can just return it.
http://www.endeavortool.com/
Old Apr 28, 2009 | 10:40 PM
69dodgecharger's Avatar
69dodgecharger
I have welded a cheep breaker bar to the nut when I had a friend in your situation. It worked, and the stud was fine, Just be carfull to cover up the rim.
Old Apr 28, 2009 | 10:52 PM
Lear31A's Avatar
Lear31A
Take it to a tire shop, this is very common. I bet for $10, they will save you alot of headaches!
Old Apr 29, 2009 | 08:25 AM
RSchleder's Avatar
RSchleder
I agree, tire shop is your best bet!
Old Apr 30, 2009 | 01:55 PM
DNAST1's Avatar
DNAST1
Hello All, McGard Tech rep contacted me and they are sending me a drill kit to remove the stud. He said the kit will include 3 drill bits increasing in size with a drill guard. The idea is to keep increasing the hole until the stud breaks free. They are also sending me at no cost a replacement lock & key. All they asked is that I return the drill kit. Once I receive the kit I will let you guys know how it goes. Now I need to go to the stealership and get new stud.
Old Apr 30, 2009 | 03:15 PM
ballzo6's Avatar
ballzo6
u can just buy a twist socket from snapon. or you can put a open end lugnut on and weld them together
Old Apr 30, 2009 | 10:52 PM
Boulty1961's Avatar
Boulty1961
If you are going to drill it then please center punch it first. That will save you from a slip that will mark up your rim.
Old May 17, 2009 | 04:41 PM
DNAST1's Avatar
DNAST1
Well guys I finally got around to drilling out the stud. It was very time consuming. The drill bit that McGard provided were dull or this wheel stud is very hard. Anyway the drill guard that McGard provide was worthless! All it did was ride up and down the drill bit as I drilled. I took the advice of tapping the stud before I started which helped. When all done the hole was slightly off center to where I nicked the wheel, rotor and hub. PISSED! It was better that I did this than someone else nicking up my iforged wheels! Cannot see the nicks anyway when the lugnut is on. Anyway put back together and test drove and all is well. Never want to do this AGAIN!
Old May 17, 2009 | 08:06 PM
coolbubba's Avatar
coolbubba
Default Bummer...
Maybe this will help the next guy- try torquing the other 4 bolts on super tight then jacking the car up and hitting 'em with the torque wrench again. You can then usually just use a small tool (screwdriver-centerpunch-chisel) to back it off as the remaining piece will have very little pressure on it. Also it never hurts to soak it in a little penetrating lube first.
Old May 18, 2009 | 08:44 AM
jimcork1's Avatar
jimcork1
I have also been worried about these locks. I bought my C5 new and when replacing (ok,, I expect to hear the you can't do that's). But I torque all the lugs to 50 ft #'s at 25# moves. Then I bring the lock lug to 65# and I bring the rest to 100#. The wheel is tight and I have never had an issue. Given all lugs are pulled up even to 50# the wheel is fully seated. The 100#'s on the 4 are basically spec. The 65# is within 30 or so % of spec. Never had an issue with rotor warping or getting the lug off.
Ok,, now lets hear the "you can't do that's".
To Wheel lock shattered (help!)
