Column Lock help... i know i know
Old Apr 28, 2009 | 11:51 AM
BLAQK's Avatar
BLAQK
Default Column Lock help... i know i know
I really tried not to post this and find my answer myself, but i'm so fecking tired of dealing with this and i cant find the damn part anywhere and no distributors can cross reference the GM part number I was given and it doesnt come up in a search.
I had the service lock issue and after way too much dicking around and having my car at two different dealerships I have a part number and a description of the part and I'm trying to find it anywhere. GM doesnt have any and nobody is making them apparently so I'm at a real loss on what to do.
Part # 19244028 from GM "harness kit for steering column lock"
do you guys know of any dealer or service center or distributor that might have this? The first dealership replaced the actual column lock mech after telling me the repair would only need a harness and relay, so I had the car moved to a local dealership that i have a good relationship with. They have been great but they just cant get the part, so I'm hunting. Thanks much for any help.
Old Apr 28, 2009 | 12:09 PM
timemender's Avatar
timemender
You should know by now that the CLB sold by various vendors who sponsor this forum is FAR superior to the GM K-Harness.
Order a CLB.
EDIT -
SEE THE STICKY at the top of C5-Tech.
Old Apr 28, 2009 | 12:37 PM
BLAQK's Avatar
BLAQK
I read throught the sticky, but unless I'm reading it wrong I thought the CLB would only work BEFORE the problem happens.
"Q Is there any solution for this problem?
A Yes; have the recall done if you have an A4 car or install a Column Lock Bypass (CLB) on MN6 & MN12 cars BEFORE the problem occurs. Once it fails, you may not be able to fix it without GM repair."
I will go ahead and get a CLB if it will solve the existing problem, but that wasn't the impression I got from the sticky.
I will check the grounds as well. Thank you.
Old Apr 28, 2009 | 01:16 PM
TEXHAWK0's Avatar
TEXHAWK0
The first Harness K kit was P/N 88952427 which was superceded by 89023816.
The part number you listed does not show to be a good number.
The reason people say install the bypass before the column locks is because you have to get the column unlocked before it can be installed. If your lockplate has been removed and the column cannot lock anyway, then you do not have to overcome that problem.
If your column still locks, then you might want to get the dealer to remove the lockplate and install a new Harnness K relay. Then you can replace it with the aftermarket version if you want.
Installing the bypass will not unlock the column. You have to get the lock pin to retract, then you can disconnect the actuator and install the bypass relay. The aftermarket relay just connects to the main wiring harness and leaves the actuator disconnected.
Does your column still lock or not? You never say exactly what your problem is. If your are just getting an error message, or if you cannot drive the car.
Old Apr 28, 2009 | 01:18 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
screw whatever GM does. get a 50$ CLB from speedinc or thunderracin g
Old Apr 28, 2009 | 01:27 PM
BLAQK's Avatar
BLAQK
the car starts and runs fine, and the column is not locked while running. I just cant go over the 2mph. I'll ask the dealership if the wheel is locked when the ignition is off.
Old Apr 28, 2009 | 01:35 PM
BLAQK's Avatar
BLAQK
okay the wheel won't lock at all even with the key out
Old Apr 28, 2009 | 02:12 PM
BLAQK's Avatar
BLAQK
will do, really appreciate the help. My appologies if this is redundant, but I have been dealing with this for like a month and hopefully this will take care of it forever. Thanks again
Old Apr 28, 2009 | 02:54 PM
timemender's Avatar
timemender
One of the GM recalls involved reprogramming the PCM to cut the fuel flow at 2MPH if it detects a problem with the column lock system.
As stated, since it appears that the lock plate has been removed, installing a working GM K-Harness or an aftermarket “CLB” will get you on your way.
IF your column lock motor itself is working, it could be hooked back up to get you going. (Column will not actually lock IF the lock plate has been removed)
NOTE: A CLB should be installed as soon as possible to remove the troublesome column-lock motor out of the equation.
The purpose of the CLB is to replace (simulate) the column lock motor assembly. (Actually the micro switches within the column lock motor assembly) The “Column Lock Bypass” (CLB) fools the computer (BCM) into thinking that the column lock motor is cycling properly).
When installing the CLB (or K-Harness) it must first be synchronized to the computer (BCM). This means the switches in the CLB must be in the correct position depending if the ignition is “On” or “Off”. In other words, the computer wants to see if the column-lock motor’s LOCKING PIN is extended or retracted. It senses this by detecting the On/Off position of the switches within the motor assembly. The same holds true when re-installing (plugging back in) the actual column-lock motor.
Lastly the final solution to guarantee that the column issue will never strand you is two fold –
1. Remove the Column Lock Plate under the steering wheel.
2. Reprogram the BCM to a fuel cut-off at 256MPH. (The max allowed by the BCM)
Find someone with “EFI Live” or “HP Tuners” (or a “Tech2”) to reprogram the MPH in the BCM. (Mostly only the dealers have the “Tech2”, and they will NOT reprogram the fuel cut-off due to perceived liability issues as dictated from GM)
Take care & Good Luck
Old Apr 28, 2009 | 04:08 PM
BLAQK's Avatar
BLAQK
cool, thanks guys. Called Thunder and got the CLB 2nd day'd. Hopefully will have my car back for this weekend and only out a few bucks.
Old Apr 28, 2009 | 05:04 PM
overBlown's Avatar
overBlown
I had the recall done on mine and yet it still failed. Same problem as yours. The column wasn't locked and it would start and run fine but not allow me over 2mph. The CLB did the trick just fine with no problems since. You shoulda asked earlier man, coulda saved you a months time fussing with it!
To Column Lock help... i know i know
