Corvette still shakes at idle
Old Apr 30, 2009 | 10:38 AM
jonwymore's Avatar
jonwymore
Default Corvette still shakes at idle
My corvette shakes slightly at idle. It also ocaisionaly has to turn over for a second before starting up. I have changed plugs and wires, and i changed the fuel filter. the fuel that came out of the old fuel filter was like mud. these did not solve the problems. Im wondering if the engine is starving for fuel so im going to check the fuel pressure at the fuel rail in the next couple days but im wondering if anyone else has any other ideas what it might be doing. There are no codes and no check engine light but "service vehicle soon" appears after it runs for a little while. I have an 02 conv. Thanks in advance
Old Apr 30, 2009 | 10:43 AM
vettelover84's Avatar
vettelover84
Stock crank and cam?
I am sure alittle shake is alright, its a 5.7 V8. Its pushing a bit of weight around in that engine..
Old Apr 30, 2009 | 10:51 AM
jonwymore's Avatar
jonwymore
yes its a pure stock car, and i wanna believe its normal and i hope its right but it didnt start doing it till about a month or two ago, but there is no noticeable affect on power so im thinking that your right. Im hoping anyway
Old Apr 30, 2009 | 10:55 AM
ericdwong's Avatar
ericdwong
How many miles? Try cleaning the throttle body, the MAF sensor (with MAF sensor cleaner) and run seafoam through it? As mentioned, the LS1 will shake a little. It's not gonna idle like a Lexus
Old Apr 30, 2009 | 11:09 AM
jonwymore's Avatar
jonwymore
it has 72,000, and what is seafoam and how do i clean those to 2 parts?
Old Apr 30, 2009 | 11:16 AM
vettelover84
Pickup some Techron at walmart or an auto parts store. That should help with the fuel tank and lines..
Old Apr 30, 2009 | 11:21 AM
jonwymore's Avatar
jonwymore
have done that too. Forgot to mention it. i have used several different bottles of fuel system cleaner
Old Apr 30, 2009 | 11:41 AM
ericdwong's Avatar
ericdwong
Seafoam is like Top Down cleaner. Do a search here on Seafoam, plenty of information and write ups.
To clean throttle body-remove the intake bellows- put the key in "ignition" but don't start the car. Have someone floor the gas or jam a stick between the gas and your stick. This will open up the throttle plate. Buy throttle body cleaner and spray the crap out of the throttle body. Use an old tooth brush and scrub the inside.
To clean MAF sensor- while you have the MAF off to clean the throttle body and use MAF sensor cleaner and CAREFULLY spray the elements.
Old Apr 30, 2009 | 11:48 AM
jonwymore's Avatar
jonwymore
thanks, that will be my weekend project for this week
Old May 1, 2009 | 12:52 AM
KRISCO's Avatar
KRISCO
Post a vid of it running so we can check it out.
Old May 1, 2009 | 12:53 AM
KRISCO's Avatar
KRISCO
Oh and throw a bobble head on the dash if you have one
Old May 1, 2009 | 07:04 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
FUEL IS LIKE MUD???????
the sock in the tank can't look good? did the car sit for years or hang out in a flood zone?
Old May 1, 2009 | 07:56 AM
RAL04VETTE's Avatar
RAL04VETTE
Since the fuel from your old filter looked like mud it's possible that your fuel injectors need to be cleaned or replaced.
Old May 1, 2009 | 09:40 AM
01vetter's Avatar
01vetter
I would also check your coil packs (may need an ignition analyzer). Even though you changed your wires and plugs, it is also possibe that you didn't seat the wires or you have a bad plug/wire. You may need to "burp" the rubber boots. They fit tightly and if any air gets caught in there when the car warms it can cause the connectors temporarily walk off the plug/coil pack connector. Do a search on the forum and you will find others have had plug burp problems that caused idle problems. To insure that you have no air trapped you can use a small plasric wire tie inserted in the rubber boot when installing then. After installed just pull out the wire tie.
To Corvette still shakes at idle
