97 vette overheating issues. Please Look!
Old Apr 30, 2009 | 07:23 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Default 97 vette overheating issues. Please Look!
The car is a 97 with about 101K on the clock. I noticed while driving the car will get hot. (230-240 ish) upon pulling over and popping the hood, I noticed coolant coming from the suge tank. I read there may be issues with this. Does anyone have a surge tank thats good? How much for a new one? How do I tell if mine is bad? im leaving tomorrow morning on vacation. once I get back I will inspect the rest of the cooling system and make sure it isnt caked with debris. would a bad thermostat cause my issues?
Old Apr 30, 2009 | 07:30 PM
lucky131969's Avatar
lucky131969
Originally Posted by 1BADGTM
The car is a 97 with about 101K on the clock. I noticed while driving the car will get hot. (130-140 ish) upon pulling over and popping the hood, I noticed coolant coming from the suge tank. I read there may be issues with this. Does anyone have a surge tank thats good? How much for a new one? How do I tell if mine is bad? im leaving tomorrow morning on vacation. once I get back I will inspect the rest of the cooling system and make sure it isnt caked with debris. would a bad thermostat cause my issues?
Look for cracks, split hoses, etc.
Old Apr 30, 2009 | 10:00 PM
SUNNYD 95's Avatar
SUNNYD 95
130-140 thats cold, they run at 200-210.
Are you sure you don't mean 230-240? Thats hot.
Old Apr 30, 2009 | 10:09 PM
MVP'S ZO6's Avatar
MVP'S ZO6
yeah thats what I meant my bust.
Old Apr 30, 2009 | 10:11 PM
MVP'S ZO6's Avatar
MVP'S ZO6
I did recently just do an intake swap and during that swap I lost some coolant. Is it possible tthat Sometime between loosing coolant and refilling the system I could've got air in the system? That would cause some issues wouldnt it?
Old Apr 30, 2009 | 10:12 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Radiator; try the upper RHS small ports, they are most likely clogged
Had this happen on a car that sat for awhile
tstat would be a good/cheap start if no foreign objects blocking rad
also, the lower shroud will cause overheat if missing
Old Apr 30, 2009 | 10:17 PM
MVP'S ZO6's Avatar
MVP'S ZO6
I will check that out thanks.
Just some FYI and added information for those trying to help me out
This issue just began. The car was fine and I didnt have the problem before I swaped over to the LS6 Intake.
Old May 1, 2009 | 07:42 AM
SteveDoten's Avatar
SteveDoten
ahhh geez, here we go
did you swap out the coolant line w/ the LS6?
Old May 1, 2009 | 07:50 AM
Oldvetter's Avatar
Oldvetter
230-240 F doesn't seem that high, check this out:
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
When you have "cooling problems" always check the radiator for foreign material (grass, leaves, plastic bags, etc.), since these C5s are bottom breathers, they act as road vacuum cleaners.
Be careful, with a leak, if air gets in the radiator, Dexcool turns to a muddy, thick brown and can foul up the cooling system.
Old May 1, 2009 | 11:23 AM
lucky131969
It's really more fun to pry information out of someone requesting help...they should not be obligated to convey the whole story up front..
Old May 4, 2009 | 06:47 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Nope, I modified the intake it self (i.e. Ground the fins off the bottom so the stock coolant line would work). I never even so much as lossened the stock coolant line.)
Old May 6, 2009 | 09:52 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Any thoughts on this..... Thanks guy's
Old May 6, 2009 | 10:06 PM
happa's Avatar
happa
I had a coolant issue, and my leak was coming form the cap on the tank. Try that first, its cheaper, may fix your problem. Good Luck
Old May 7, 2009 | 10:15 AM
C5Luv'R's Avatar
C5Luv'R
Start with a new tank cap. I recently had mine go bad and it caused coolant to slowly boil off until the car was low on coolant. Then refill the cooling system and perform the GM air bleed procedure (available on the Forum, just search for it). Check for any hose leaks. If none of that helps, then look into your intake installation.
Best of luck!
Old May 7, 2009 | 10:26 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Too much!
Old May 29, 2009 | 12:20 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Best of luck!
thankyou. Just out of curiosity what might my intake installation have to do with this? What should I be looking for?
Old May 29, 2009 | 09:54 AM
HWY HNTR's Avatar
HWY HNTR
both fans working? check fuses 43 and umm i think 48 in the engine bay. Last time my car was at 230 was when fan1 blew fuse.
To 97 vette overheating issues. Please Look!
Old May 31, 2009 | 01:25 AM
MVP'S ZO6's Avatar
MVP'S ZO6
well thermostat is fine replaced the cap with a new one a few days ago.* the* the car is better (not pissing coolant out after running on the interstate anymore) but shes still running a bit hotter then I would like.* after a highway run she kicks up to about 230ish and then the fan kicks on and brings here back down between 217-220 in 6th gear at 70 MPH shes just below 220.* it dont seem to get hotter then about 233.* the next thing im going to do is spray off the radiator with a hose.* theres no road debris in front of the radiator but maybe theres some dirt between the fins or something. i may also add some watter wetter.* id like the car to run at between 205 and 210 on the interstate.
Old May 31, 2009 | 02:36 AM
jedblanks's Avatar
jedblanks
In addition to the other items people mentioned:
There is a small overflow line running from the top of the surge tank to the top of the radiator. My nipple was broken off at the radaitor.
Check that nipple.
You could also have a surge tank cap that doesn't seal.
Anything that allows the system to loose the 5-8 psi pressure it needs will lower the boiling point and allow it to heat (slightly).
on another note I feel these cars run to hot from the factory-- not unusuall to see 235 on a hot day in traffic.
I'd recommend and 180 degree thermostat + adjust cooling fans to come on earlier. low speed on at 190ish high speed on at 205-210.
Keep the temps around 190 instead of 210+
Old May 31, 2009 | 11:19 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The surge tanks are about $50 for new ones depending on where you get it from. The nipple line on it will crack over time therefore the system will lose coolant and pressure. Where was the coolant coming from on the tank? Cap or other place such as the nipple line?
