Need some help uninstalling some interior parts. Any help/tips/pics/directions would be greatly appreciated.
Need help taking off the circular pieces around the door handles. Also need help taking off the circular pieces around the seat controls and the seat adjust pivot arm.
This will get you started.
Pocket size screwdriver in 2 slots, bottom one first, pull bottom out a little, then top, pull top out a little, then pull evenly all around, it'll pop right off.
With a suitable blunt ended tool inserted between the cushion and the handle push the handle retaining spring clip down.
Pull the handle from the shaft.
