A/C - Please help
Old May 3, 2009 | 09:53 AM
SaberD's Avatar
SaberD
Default A/C - Please help
i checked all my fuses and the wires that go to the compressor, and they all appear to be ok. My AC light stays on when i press it. It doesnt flash or anything. However, the clutch never engages. Do the AC relays go bad often? How do i check to see if the relay is working or not?
Old May 3, 2009 | 01:48 PM
jlf04's Avatar
jlf04
Have you checked your Freon?
Old May 3, 2009 | 05:05 PM
c5streak's Avatar
c5streak
Easy way to trouble shoot the relay is to swap it with one that works. Look in the elect panel under the hood, see which is labeled A/C( I think it may be #34) and swap it with the one labelled horn. If the A/C works and the horn doesn't, you have a bad relay.
Old May 4, 2009 | 08:20 AM
SaberD's Avatar
SaberD
if the freon is low i should get a code, and the light on the ac button will blink. i'm getting neither.
Old May 4, 2009 | 09:48 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Check the wires going to the compressor. My plug broke somehow and that was my issue. I jacked up the car and looked through the wheel well. You can check for voltage at the pressure switch with the A/C on too.
Old May 11, 2009 | 03:45 PM
SaberD's Avatar
SaberD
i checked the plug going to the compressor (the one you can see from above the engine), and it seems to be fine. i also switched the relay with the horn, and still nothing. any more ideas? (i dont have a voltmeter btw :P)
Old May 11, 2009 | 04:20 PM
lucky131969's Avatar
lucky131969
Ok, so how do you want to proceed? You will need a DMM to verify 12 volts and ground at the compressor connector at the very least. If you have 12 volts, and a good ground, then the clutch is probably toast(another thing you can check with a DMM).
To A/C - Please help
