2nd gear grinding AGAIN
Old May 7, 2009 | 01:21 PM
99FRC Newb's Avatar
99FRC Newb
Default 2nd gear grinding AGAIN
i'm thinking its a bent shift fork or something. it only has about 10k miles on it since the rebuild (stock parts), but the place that warrantied it only replaced the gear and synchro. they didn't diagnose anything.
if you don't hold it in gear when you are letting the clutch out, it will pop out of gear and grind. once you let the clutch out, its fine though
what else could it be?
and no, it doesn't need the "driver mod"
Old May 7, 2009 | 02:22 PM
ericdwong's Avatar
ericdwong
Damn that sucks. Put the correct fluid in there?
Old May 8, 2009 | 02:56 PM
99FRC Newb's Avatar
99FRC Newb
i don't know what fluid is in it. the place i bought it from (which "warrantied" it) is now out of business with MANY fraud charges against them. they probably reused the old fluid to save money.
Old May 8, 2009 | 03:50 PM
ericdwong's Avatar
ericdwong
Good lord. Well try to change the fluid first see if that helps, do not use Mobil 1 Synth ATF with a '99.
Does it feel like the shifter still "detents" slightly when putting it into/taking it out of gear?
Old May 10, 2009 | 10:45 AM
Nver2loud's Avatar
Nver2loud
If its falling out of gear, i beleive that is a key problem for the syncro sleeves.
Old May 10, 2009 | 12:17 PM
rcrosier's Avatar
rcrosier
had the same problem with a 98 mustang cobra I had way back.... only happened in second gear, but became more and more frequent as time went on. after getting syncro replaced, it was perfect.
Old May 18, 2009 | 02:20 AM
99FRC Newb's Avatar
99FRC Newb
well, synchro was replaced and it did it again shortly after
Old May 18, 2009 | 07:25 PM
02Z06clark's Avatar
02Z06clark
I have 02 z06, same issue except reverse, it was the shift fork, I was lucky since I purchased GMPP Extended Warranty.
Old May 19, 2009 | 10:10 PM
99FRC Newb's Avatar
99FRC Newb
i just bought an MN12 to throw in. should take care of the problem
Old May 20, 2009 | 07:58 AM
LT1vette's Avatar
LT1vette
Hi....WHY can't you use Mobil1? and.... The tranny he is talking about is a manual, so why put ATF fluid in it ?
TIA
To 2nd gear grinding AGAIN
