I *think* I found a brand new problem
Now to stop the rambling, and throw out this new problem i'm having that I don't *think* anyone has come across or addressed on here yet. (my apologizes if I'm wrong and I just wasn't using the right search terms). Periodically while I'm driving, with the heat/AC off, the blower will kick on and start running on it's own, usually the defroster. It'll then fade in and out, on and off, for no particular reason. The only way to make it stop running on it's own is to turn on the heat/ac, even the lowest fan setting, and it will work like normal. What makes this worse is that now the blower is running even when the car is off. However you turn the car on, and it turns off. Turn the car off, take the key out, and yep...the blower turns back on. After hearing it run for about a half hour tonight, i finally resulted to just unplugging the battery till the morning...couldn't figure out how else to stop it.
Anyone have any idea what might be going on here or where i could even start to look?
Thanks in advance for any ideas if ya got 'em
DEFINITION: Blower motor is on at any selected speed.
1
Was the blower motor system check performed?
Go to Step 2
Go to HVAC Blower Control (CJ2) System Check
2
Disconnect the HVAC programmer module connector.
Turn the ignition switch to the RUN position.
Is the blower motor on?
Go to Step 3
Go to Step 4
3
Turn the ignition switch to the OFF position.
Disconnect the blower motor control module connector.
Connect a test light between terminal C of the blower motor control module connector and a known good ground.
Does the test light illuminate?
Go to Step 5
Go to Step 6
4
Replace the HVAC programmer module.
Is the replacement complete?
Recheck System Operation
5
Connect a test light between terminal B of the HVAC programmer module connector and a known good ground.
Go to Step 6
Go to Step 5
6
Locate and repair a short to B+ in CKT 63.
Is the repair complete?
7
Replace the blower motor control module.
Also, download the DVD maintenance manual;
http://forums.corvetteforum.com/c5-t...al-on-dvd.html
And yes, this is a new one.... congrats!
Peter
