Rearview mirror removal???
Old May 9, 2009 | 11:32 PM
Z06ster's Avatar
Z06ster
Default Rearview mirror removal???
I have an '02 Z and because of a failed mod attempt, I need to now remove my review mirror to repair it. I went to the '02 Factory Service manual and it shows there is a single screw you remove to pop it right off. Well... the manual lied because there is another style where a clip appears to hold the mirror in place. Because this clip is right behind wind shield, it is nearly impossible to see let alone reach.
Could anyone out there please tell me the procedure to remove this rearview mirror. I'm wondering if perhaps there is a special GM service tool I need???
Thanks,
Matt
Old May 9, 2009 | 11:57 PM
LoneStarFRC's Avatar
LoneStarFRC
Mine is held on by one T20 Torx-head screw. You the original owner? Factory mirror?
Old May 10, 2009 | 12:14 AM
byronhunter's Avatar
byronhunter
Rearview Mirror Replacement DD8
Removal Procedure
Remove the electrical connector (1) from the back of the inside rearview mirror .
Important
Do NOT pull rearward on the mirror while removing the mirror or damage to the support and/or windshield will occur.
Rock the mirror from side to side pushing upward firmly. An audible click is heard when the inside rearview mirror is releasing from the support.
Remove the inside rearview mirror support.
Installation Procedure
Install the electrical connector (1) to the back of the inside rearview mirror.
Perform the following steps to install the inside rearview mirror:
Center the bottom of the inside rearview mirror on the support.
Important
Do NOT pull rearward on the mirror while installing the mirror or damage to the support and/or windshield will occur.
Rock the inside rearview mirror from side to side while pushing downward firmly. Take care not to damage the windshield.
An audible click is heard when the inside rearview mirror is fully seated.
Old May 10, 2009 | 05:10 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I haven't heard of the rocking technique for the Electrochromatic mirror, I use a mini pry bar and depress the clip while someone outside the car guides me...
Matt, I'm really sorry you're gong through all this grief!
Old May 10, 2009 | 11:03 AM
byronhunter
tstar, that is cut and paste directly from the '02 Service Manual.
Old May 10, 2009 | 11:34 AM
LoneStarFRC
Either you've got a different version of the '02 service manual, or the OP looked in the wrong place in his.
Old May 10, 2009 | 12:17 PM
ljthe2nd's Avatar
ljthe2nd
I have removed a dozen or more electrochromatic mirrors and I have never gotten the rocking method to work. There is a tool that you can buy
http://www.technologylk.com/product/...tm?src=froogle
read the instructions for this tool.
I use a Craftsman 10" pry bar and can remove a mirror in less than 10 seconds
http://www.sears.com/shc/s/p_10153_1...aftsman+prybar
Just insert the pry bar as far as you can and firmly push towards the windshield on the end of the pry bar while pulling up on the mirror and it will com off
Old May 11, 2009 | 03:26 AM
tstar's Avatar
tstar
I wasn't calling you out, I had just never heard of it and to be honest I never looked in the Service Manual...
Tim
To Rearview mirror removal???
