Please help, DIC Code P0140
Old Feb 4, 2002 | 06:07 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Please help, DIC Code P0140
Hi guys,
Do you have any details on code P0140 [Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2-B]? I looked at the IPC Code doc under the Tech section but couldn't find anything useful.
Thanks in advance.
-Tuan
Old Feb 4, 2002 | 07:41 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Please help, DIC Code P0140 (Tuan Le)
DTC P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
The powertrain control module (PCM) supplies a voltage of about 450 mV between the HO2S high and low signal circuits. The oxygen (O2) sensor varies the voltage over a range from about 1,000 mV when the exhaust is rich, down through about 10 mV when the exhaust is lean.
The PCM monitors and stores the heated oxygen sensor (HO2S) voltage information. The PCM evaluates the HO2S voltage samples in order to determine the amount of time the HO2S voltage was out of range. The PCM compares the stored HO2S voltage samples taken within each sample period and determines if majority of the samples are out of the operating range.
The PCM monitors the HO2S voltage and detects if the voltage goes out of the bias range. If the PCM does not detect the voltage went out of the bias range, a DTC sets.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0112, P0113, P0117, P0118, P0125, P0200, P0335, P0336, P0351-P0358, P1120, P1220, P1221, P1258 are not set.
The engine run time is more than 70 seconds.
The fuel system is operating in Closed Loop.
The AIR and the catalyst diagnostics are not active.
Conditions for Setting the DTC
The HO2S signal voltage is steady between 409 mV and 489 mV for 2.5 minutes.
Action Taken When the DTC Sets
The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important
Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.
For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
An oxygen supply inside the HO2S is necessary for proper operation. The HO2S wires provides the supply of oxygen. Inspect the HO2S wires and connections for breaks or contamination.
Old Feb 4, 2002 | 07:52 PM
Former Vendor
Default Re: Please help, DIC Code P0140 (kewlbrz)
Thanks Shawn.
I need a beer after reading your post. :D
-Tuan
Old Feb 5, 2002 | 05:23 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
It's probably a fuse, mine was. I think it was in the line. The o2 senser needs to be heated and if its not it sets a code.
JB
Old Feb 5, 2002 | 11:23 AM
TLewis4095's Avatar
TLewis4095
Default Re: Please help, DIC Code P0140 (jbsblownc5)
I installed O2 sims and have not seen the code since :D
To Please help, DIC Code P0140
