Here are the "Performance Mods" that I'll be doing. Need your input please
-MTI 7.0 LS1 long block.
-Stage 3 LS6 heads
-R1 cam (232/237/114LS @ .560 lift)
-ASP Underdrive Crank Pulley
-FLP Level IV 4l60E (with SuperYank 3500 converter) - Almost completed
-Getrag 3.73 gears - already sitting at the garage
-B&M 24,000 GVW transmission oil cooler
-Ed Wright PCM tunning
I have mainly two issues that Iam still thinking of & would appreciate your help
-From a reliability point of view, is there anything else in my C5 that needs to be upgraded to handle the extra hp & higher RPM range beside the above listed ? Are there any pumps (fuel pump, oil pump, coolant pump, etc) that needs to be upgraded ? My car is a 2001 model, so some of those might be already revised from the factory. I drive my car only on weekends with some occasional street racing. Track will not be visited more than once a month.
-From a performance point of view, do you think that Iam leaving any HP on the table ? My car already has the mods listed in my signature. Is there anything else worth some other HP ? Furthermore, what injectors do you recommend going with ?
I know, the run-flats are not going to be happy about all this :D :D :D
:seeya
[Modified by Corvette4ever, 5:12 AM 2/5/2002]
In addition if you keep the 3.73s and are goung to drive the car hard (at any time) you may need 30# injectors.
I just had 3.73s installed and will be getting the 30# injectors on 2/15. Additional tuning will also be required if you switch out injectors.
Great set of mods, good luck!
Chuck
I also think a Doug Rippie Motorsports Heavy Duty Radiator/Oil Cooler would be a great addition. It is very important to keep the oil cool in a superstroker motor such as this. This unit is once piece and comes with all of the AN fittings, braided lines and oil filter re-locator you need for the install. One of these is going on my ARE 436ci that should be dropped in within the next 6 weeks.
Iam gonna get the pulley from MTI (it might come installed with the engine, not sure yet)
That is one hell of a cam :eek: What are going to use this car for?
Iam not going to road race my car, do you still think that I should still get the Heavy Duty Radiator/Oil Cooler ?
I thought the stock output shaft would hold up to 600+rwhp :confused: . Thanks anyway, I'll look into that.
(use the search function).
I've seen folks with Heads/Cam & N20 setups break them as well.
Some were on ET Streets some were on regular tires.
If I was going to throw a 7 lter monster in I would definately replace the output shafts. As matter of fact, I will probably swap 'em before too long. :yesnod:
This is coming to you as personal opinion by me, because I do not even sell these radiator/coolers. However, I wish I did so I could get one for my own 436 for cheaper :D
I would also recommend the headers (TPIS LT's on my 2001) fit great and Lot's of torque:crazy:(check out my homepage for fiull install of TPIS)
I also have the 3.42's.The car goes sideways from a 25 mph roll..3.73's might be overkill...Good Luck!:D
What about the oil pump & fuel pump ? since my car is a 01 model then I guess it already has the LS6 oil pump. Is the LS6 pump enough for my setup or do I have to go for a further modified unit ?
I keep adding things but when I am done I will be sure to let you know.
Patrick :seeya
That is CRAZY! What kind of "penalty" is it? Money? Jail? :D
Patrick :seeya
