Rear View Mirror Passenger Side
Old May 11, 2009 | 11:22 AM
BATM4N's Avatar
BATM4N
Default Rear View Mirror Passenger Side
Has anyone actually taken off the bottom part of the rear view mirror? There is a spring and a washer that holds the two pieces together but looks and feels like once I take the washer off, you'll never be able to get it back on again. Is this a "Once you take it off, you have to buy a whole new rear view mirror" piece?
Old May 11, 2009 | 11:35 AM
byronhunter's Avatar
byronhunter
I would not try AGAIN unless it was really nessary. Thay are being repaired with parts from Lowes. Small threaded pipe from the lamp dept. Some are drilling a hole and putting a pin through it. It's a PITA. Why do you need to take it apart?
Old May 11, 2009 | 12:26 PM
TEXHAWK0's Avatar
TEXHAWK0
The base of the mirror is not designed to be removed.
In fact, quite a few forum members have had the mirror fall off, and have had to come up with alternate methods to re-attach it.
If you do a search you should be able to find one or two methods.
If you mess with the one time press on clip, you will break it, and will have a bigger problem than you have now.
I like the way this guy fixed it...
http://forums.corvetteforum.com/c5-t...de-mirror.html
Old May 11, 2009 | 04:21 PM
BATM4N's Avatar
BATM4N
Originally Posted by TEXHAWK0
The base of the mirror is not designed to be removed....If you mess with the one time press on clip, you will break it, and will have a bigger problem than you have now.
Thanks for the reply guys. I wanted to have both pieces re-painted professionally and best way for that was to have them separated, but not going to work out.
I'm glad I stopped while I was ahead. I had a feeling something wasn't right, so good to know that clip is not designed to come off and then force a bad situation.
Thanks again
Old May 11, 2009 | 06:53 PM
byronhunter
I just panted one for my car. I rotated the base just a few degrees, that causes the space between the housing and base to open up enough for the painting process. Can't tell it from the factory paint.
Old May 12, 2009 | 12:32 AM
BATM4N's Avatar
BATM4N
Thanks for the info Glad to know that it won't be obvious that it was painted
To Rear View Mirror Passenger Side
