Steering fluid question
Old May 11, 2009 | 03:56 PM
justin_heat05's Avatar
justin_heat05
Default Steering fluid question
My steering pump has been completely empty and I filled it and it has tight steering and sometimes makes a rattle noise when I back up and turn the wheels. Could there be air in the system or is the pump failing?
Old May 11, 2009 | 04:19 PM
Tkoscielniak's Avatar
Tkoscielniak
Very likely there is air in the line if it was empty. After filling it up and turning lock to lock sever times usually purges the air. A whine occurs normally when there is air in the line also. When you pump is going out the steering will normally get very hard to turn. I would be concerned about where the fluid is going also.
Old May 12, 2009 | 08:26 AM
justin_heat05
I had to take the engine cradle out and I emptied the steering fluid.
justin_heat05
would not using synthetic cause hard steering?
Old May 12, 2009 | 08:36 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Try jacking the front tires off the ground, and making several rapid lock to lock turns.
Leave the P/S pump reservoir cap loose when you're doing it, to help expel any trapped air bubbles in the system.
Old May 12, 2009 | 12:27 PM
C4B4the04's Avatar
C4B4the04
GM calls for the use of a vac pump to get the air out using a special fitting and a hand pump, IIRC. I made one out of a stock power steering cap, drilled a hole and screwed in a vac. fitting. Then I sucked a few inches of vacuum on it, cranked the wheel back and forth fully a few times, then released the vacuum. Sucked all the air out of the system. Done it that way to two cars, not a squeel or noise out of either. Must have done something right....BTW, I use Red Line Synthetic Power Steering fluid (has a higher boiling point...I was boiling regular fluid on the track).
HTH,
Cassidy
Old May 12, 2009 | 12:52 PM
Quicksilver Vert 01
HTH,
Cassidy
Sounds perfect!
I never thought of applying a vacuum source to it.
Old May 12, 2009 | 02:13 PM
justin_heat05
thanks for the advice guys, I hope it works
To Steering fluid question
