Changed Tranny Fluid.....Big change
Old 05-13-2009, 08:25 PM
cbell3186
cbell3186's Avatar
Default Changed Tranny Fluid.....Big change
so I changed my trans fluid in my M6 and replaced it with DEX III and to be honest its worse than before, so much more notchy and harder to get into first gear..... any recommendations as to why?
Old 05-13-2009, 08:29 PM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
you havent filled out your profile so we have no idea what year your car is to offer help or suggestions
Old 05-13-2009, 08:49 PM
cbell3186
cbell3186's Avatar
ah crap 99 FRC Manual with 45k
Old 05-13-2009, 08:52 PM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
I did mine last weekend ( 02 Z06 ) with Redline's D4 ATF and it made a clear difference for the better, especially once it gets warmed up.
What brand did you use?
Old 05-13-2009, 09:20 PM
cbell3186
cbell3186's Avatar
I used the dex 3 that napa recomended I want to say valvoline.....
Old 05-13-2009, 09:24 PM
bumble-z
bumble-z's Avatar
Same here, made a big difference.
Old 05-14-2009, 01:28 PM
cbell3186
cbell3186's Avatar
Where can I find/order that stuff from....?
Old 05-14-2009, 02:04 PM
Sinister-one
Sinister-one's Avatar
You should have used...
AMSOIL Synthetic Universal Transmission Fluid.
http://www.amsoil.com/storefront/atf.aspx
This stuff works wonders !!
Old 05-14-2009, 02:08 PM
bumble-z
bumble-z's Avatar
If you're referring to Red line products , can be ordered from Jeg's. They deliver to your door in a couple days.
Old 05-14-2009, 06:07 PM
SPS
SPS's Avatar
I don't understand it. You sure you got it full. It should have made a big difference. About 6 years ago, I was almost ready to bring in the tranny for a rebuild, but I replaced the fluid with Mobil 1 ( some people are now going comment about Mobil 1 and paper rings ), and it was almost like new.
Old 05-14-2009, 07:11 PM
sami85L98
sami85L98's Avatar
I did last year still no problems and i highly recommend. Get the Amsoil ATF for ur manual. You need 3.5 qts approx.
Old 05-14-2009, 09:10 PM
Fire 22
Fire 22's Avatar
Did mine over the winter and noticed a difference for the better.
Old 05-14-2009, 09:41 PM
Oldvetter
Oldvetter's Avatar
Did you have your C5 from new? If not, it is possible that a previous owner replaced the trans fluid with a synthetic. You replaced the synthetic with regular dextron and it is now worse.
All 1997-2000 C5s have paper blocker rings and Mobil 1 is NOT compatable. I used Mobil 1 for nearly 50,000 miles in my 1998, but then it started grinding going into 6th gear (couldn't have been sycronizers, who speed shifts into 6th). I changed fluid to Amsoil ATD and it stopped immediately !
Old 05-14-2009, 10:20 PM
TGstring
TGstring's Avatar
Location: cruising between USA and Canada... SAVE THE WAVE!
I just did a COMPLETE fluids flush today and dropped in exactly what the owner's manual recommends for a '98: Dexron III ATF.
bought a jug of castrol for around $15 and the tranny shifts like a dream.
I've read into posts on the paper ring situation extensively and have found that those in the know say stay away from synthetics.
FWIW, the car has over 90k miles on it but you'd NEVER know by driving it.
Old 05-14-2009, 10:46 PM
cbell3186
cbell3186's Avatar
ok maybe I didnt fill it up all the way, I think i used about 3 qts, I want to say maybe a tad bit less, I was thinking it was a little low but it was pouring out of the fill hole, and the car was completely level.....any thoughts?
Old 05-14-2009, 11:36 PM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
It is probably full. Mine usually took about 3 1/4 quarts after draining. Personally, I'm not a fan of most Dexron III fluids as they use conventional basestock and shear down very quickly. I am clearly biased, but I've been using the AMSOIL fluids in my 02 Z06 and 06 CTS-V for years with very good results.
For those ordering AMSOIL using the above link directly to AMSOIL, would appreciate it if you used reference #1206638 so my dealership and the forum benefit from the sale.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 05-14-2009, 11:40 PM
Professorsc5
Professorsc5's Avatar
I changed the fluid in my 98 6 speed and used Royal Purple. Not perfect but a big difference. The first to second shift is a lot smoother now. You might want to do a little more research before you change the trans fluid again.
To Changed Tranny Fluid.....Big change
Old 05-15-2009, 03:06 PM
dbbspider
dbbspider's Avatar
Default Atf
I just replaced the stock fluid in my 99 coupe M6 at 65k miles with Castrol Dex/Merc Domestic Multi-Vehicle ATF. ON the bottle, is says, Recommended for use in all 2005 & prior GM automatic transmissions. I never had a problem with the old stock fluid (it was still nice and red when I drained it), and I do not have any problems with the new fluid. It shifts just fine.
Old 05-15-2009, 03:14 PM
Sinister-one
You da man !
I'm a dealer under Brad.
You couldn't find a nicer guy or a better product !
Old 05-15-2009, 06:30 PM
cbell3186
cbell3186's Avatar
Fixed it, now it feels a lot better, I jacked up the driver side way up, and filled it, surprisingly the trans was still pretty level, but topped it off with another half quart or so....
Quick Reply: Changed Tranny Fluid.....Big change
