Electrical gremlins and hard starting
Old May 13, 2009 | 09:28 PM
TheKing43's Avatar
TheKing43
Default Electrical gremlins and hard starting
I have a 98 Convertible with 6700 miles on it. I had dead battery troubles last year and bought new Optima battery and leave it on a battery tender when getting regular use. This eliminated my troubles for several months. the car had been leech tested and showed all modules shutting down correctly and not reawakening.
But now I seem to be developing electrical gremlins. My battery tender shows a full charge, and when driving the DIC shows the alternator charging fine, but when I go to start the car, the starter solenoid clicks like a low battery but then the engine will slowly turn over and start most of the time. i can drive for 15 minutes, then after sitting for an hour, the solenoid still clicks 1st when trying to start. tonight i noticed that on regular intervals, the lights, both exterior and interior will dim for a second then go back to normal during driving. this happens at regular 5 to 10 second intervals. does this sound like voltage regulator going bad, or starter solenoid? any insight would be great!
Old May 13, 2009 | 10:10 PM
byronhunter's Avatar
byronhunter
First get the battery load tested.
Old May 15, 2009 | 05:58 AM
TheKing43's Avatar
TheKing43
the thing throwing me off is the light dimming...it comes at regular intervals and for consistent duration...not intermittent or varying...almost like consistently hitting a missing tooth on a gear...thats what turned my thinking towards a module or regulator
To Electrical gremlins and hard starting
