check engine light
Old May 14, 2009 | 07:18 AM
CJ454's Avatar
CJ454
Cruise-In II Veteran
Default check engine light
I read the code and it said P01416. Called the dlr and they said no such code.
they had a 1516 but that was it. They said I was reading the code wrong. doubt that... I think they just want the $75 or $90 to put it on the computer
Any idea on what this is?
Car was and is running fine. I cleared the code see if it comes back again.
prpbably should have mention this is on 2000 vert
Old May 14, 2009 | 07:35 AM
dougbfresh's Avatar
dougbfresh
Originally Posted by CJ454
I read the code and it said 1416. Called the dlr and they said no such code.
Did you try the SEARCH function above-common code.
Old May 14, 2009 | 07:39 AM
CJ454's Avatar
CJ454
Yes said sorry no matches when i searched.
Old May 14, 2009 | 07:42 AM
CJ454's Avatar
CJ454
I just tried a search with out the leading 0 that turned up something.
Not sure what they are talking about in the post.
http://forums.corvetteforum.com/c5-t...and-p1416.html
Old May 14, 2009 | 07:54 AM
CJ454's Avatar
CJ454
After reading several posts I think this one has a good explanation
http://forums.corvetteforum.com/c5-t...eck-valve.html
Old May 14, 2009 | 07:59 AM
lucky131969's Avatar
lucky131969
Yep, you've got it.
Old May 14, 2009 | 08:15 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It sounds like another dealer to stay away from!
P1416 is a legitimate trouble code.
Old May 14, 2009 | 11:01 AM
dougbfresh's Avatar
dougbfresh
I got 64 returns
Old May 14, 2009 | 03:14 PM
CJ454's Avatar
CJ454
well the dlr did call me back and fax me some info so he was cool just late last night and he wanted to go home i guess.
Old Jun 1, 2009 | 10:28 AM
CJ454's Avatar
CJ454
I cleared the code and drove the car for a few and it did not come back. i did the cleaning but the car has been sitting due to all the rain we have been getting. I hope to have it out this week to see if that fixed it.
My dlr gave me the same info on this too.
Old Nov 23, 2009 | 11:16 AM
CJ454's Avatar
CJ454
Well I got this 4 times over the weekend (cleaned several time) . I am going to try and replace the easy one first and see if that works.
Old Nov 23, 2009 | 06:35 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Why would you do that??? The code is for the passenger side not the Driver's side...
Old Nov 24, 2009 | 06:41 AM
CJ454's Avatar
CJ454
it is? I get 2 different codes I forget which one is which. But either way I think i have to replace both of them so I am starting on the easier one first.
Old Nov 25, 2009 | 03:50 AM
tstar's Avatar
tstar
Oh sorry, I thought you were only getting the 1416, Passenger check valve code...
Tim
Old Nov 30, 2009 | 06:44 AM
CJ454's Avatar
CJ454
ok so i changed the driver side out and got a check engine light this morning on the way to work. Have not had time to check the code but I have a feeling its the passenger side one.
So is there any good write-ups on how to gain access to replace that one.
I see posts from people saying it s a pain and hard to get to etc. But how did they accomplish it? wrench sizes and what did you take off to get to it etc.
I may see if a local mechanic i use can do it for me. I am sure the dlr will be way to much $$$
Old Nov 30, 2009 | 05:03 PM
CJ454's Avatar
CJ454
Code was 0410..some sort of airpump code according to the web. But it refers to water in the airpump in cold climates..I'm in sfl
Thoughts on what to check..
Could this be the passenger side valve
Old Nov 30, 2009 | 05:38 PM
lucky131969
Not sure where the water in the pump conclusion is being drawn from. The P1416 is consistent with the passenger check valve(already discussed). There is no need to guess on the codes.
http://www.c5forum.com/ayc/dtcdic.php
Typically, the P410 sets if both banks do not respond during the test, not just one. If both check valves were bad, and you replaced the drivers side, then the P410 should clear, and the P1416 will remain. Can you hear the AIR pump running when the car is started initially?
To check engine light
Old Nov 30, 2009 | 06:59 PM
CJ454's Avatar
CJ454
Old Nov 30, 2009 | 07:48 PM
lucky131969
Are you reading the posts in this thread, particularly #17?
So again. Is the AIR pump running on start up? Do you have an existing (current) P410 that will not clear? Do you still have a P1416? Are you checking the codes through the DIC, and clearing per the instructions I posted?
Old Dec 1, 2009 | 07:28 AM
CJ454's Avatar
CJ454
Sorry my update freaked out I was posting from my Droid. not my computer.
I got the code from this site. And called my dlr. http://www.obd-codes.com/p0401
Dlr said the water thing was for a 2002 Camaro issue.
I was driving like 10 miles when it came on with the p0410 code. No more p1416 code. (at this time)
I cleared the code yesterday on the way home from work and it did not come back. I am not driving the car today but I will check it in the next day or so.
I am still going to replace the 2nd valve soon.
