Whats the best way to change the oil on a c5 ?
I do have an 02 zo6 but have only changed it 3 times myself.
Was wondering if there were any new and better ways of doing it ?
Thank You
Are you kidding? It's just an OIL CHANGE, you do it the same way you did the other 3 times. Jack up the car, remove the filter and drain plug. Drain oil, new filter, put plug back in, fill with 6.5 qts.
I found the easiest way is to remove the oil plug and let the oil drain into a pan. I tried turning the car upside down and letting the oil drain out the dipstick tube, but that was much more difficult.
However, turning the car upside down was less messy when removing the oil filter.
when I drive the car on ramps, then I jack up the rear a little higher than the front, at that point what is a way to keep the car stable .
last time I did it ,it started to roll back while I had the jack stand in my hands
I was lucky and just muscled the car forward , but there could have been a problem
