C5 Exhaust Question
Old May 18, 2009 | 10:57 PM
coolbreeze803's Avatar
coolbreeze803
Cruising
Default C5 Exhaust Question
I was wondering what kind of performance gains can i expect if i were to open up my c5 stock exhaust cans and remove the baffles or what ever is inside them and then weld them back together, has anyone out there ever tried this or heard of anyone trying this please advise.. thanks...
Old May 18, 2009 | 11:01 PM
Z06BlackOut's Avatar
Z06BlackOut
3rd Gear
ive never seen anyone do this i dont think you would see much performance gains. its up to you. if looking for a better sound and performance just run a Cut out set up. that would be the way to go. instead of spending 1000$ on a exhaust system
Old May 18, 2009 | 11:47 PM
98BuickRegalGS's Avatar
98BuickRegalGS
I'm still new to vette ownership so dont take my word as gospel I remember motor trend put a corsa system on a C5 and it only gained like 4 horsepower over stock.
Old May 19, 2009 | 12:14 AM
c5blkvetteguy's Avatar
c5blkvetteguy
I think changing the rear section out is more for sound than horsepower.
Old May 19, 2009 | 01:16 AM
LightFighter_GXP's Avatar
LightFighter_GXP
change rear exhaust to save some weight and or to add some nice sound!!
Old May 19, 2009 | 01:27 AM
lucky131969's Avatar
lucky131969
The winning answer !!
Old May 19, 2009 | 09:14 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
It depends. Put a pressure gauge on a couple places in your exhaust system. If you have a relatively large pressure drop across the mufflers, opening them up would help your exhaust flow (and engine VE). If most of the pressure drop is before the mufflers, then the muffler work probably wouldn't be very value added. Only a gauge or a timeslip will tell you.
To C5 Exhaust Question
