replacing rear wheel studs.
Old May 19, 2009 | 04:39 PM
deadbeatrec's Avatar
deadbeatrec
Default replacing rear wheel studs.
is there a DIY out there? if i dont have to take off the hub i dont want to. can i just drill a clearance hole in the plate behind the studs and pound them out?
FYI, im running a spacer and i want longer ARP wheel studs. lowered the car this weekend and i have 11" CCW wheels in the back and the spring hits the wheel.
Old May 19, 2009 | 05:25 PM
Bill Dearborn's Avatar
Bill Dearborn
You can drill a hole in the plate but it will have to be very close to the parking brake mounting point. Be careful when drilling so you don't screw up the parking brake. I have a hole in the passenger side plate and there isn't much meat between it and the hole for the parking brake.
Bill
Old May 19, 2009 | 05:34 PM
deadbeatrec
Bill
pics.....i will need them if anyone has them.
from this thread
http://www.z06vette.com/forums/f117/...acement-44186/
people are getting scared and opting not to drill the hole because they cant seem to find a spot to drill. this scares me a little. anyone have pics of it drilled?
the dealership wants $600 to replace all the rear studs. F that!!!
Old May 19, 2009 | 09:21 PM
Bill Dearborn
from this thread
The dealership mechanic is the one who drilled the hole. He suggested doing that instead of tearing the whole assembly apart to replace one stud. All he needed was my permission to do a non-standard procedure. Cut quite a bit off the repair bill.
Follow the directions in the LG post in that other forum.
Bill
To replacing rear wheel studs.
