New tires/traction control
Old May 21, 2009 | 12:11 AM
rebelheart's Avatar
rebelheart
Default New tires/traction control
I am putting some 245/40-18 tires on the front, they have a circumference of 80.8 and a diameter of 25.7 with a rev/mile of 784,on the back I am putting 305/30-19 with a circ of 82.3 inches and a diameter of 26.2 with rev/mile of 770. the tire calculator site says this is a difference of 1.9% Does anyone know if this will mess with my traction control?
Old May 21, 2009 | 01:38 AM
KRISCO's Avatar
KRISCO
I think if you maintain atleast 1\2 inch you are ok. Im sure someone will verify this.
Old May 21, 2009 | 12:28 PM
Oldvetter's Avatar
Oldvetter
They are right, 1/2 inch is the minimum difference. Stock tires have 1 inch difference.
Old May 21, 2009 | 12:42 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Mine are a little less than .5 difference in diameter and I have no traction control issues (>>knock on wood). When I had the same size tires all the way around, I would get the traction control randomly coming on and even slowing the car down at times. You should be fine with that combo.
Old May 21, 2009 | 02:00 PM
Oldvetter's Avatar
Oldvetter
Remember, on a Corvette the rear tires tend to wear down faster than the fronts, so you don't want to have this problem later (after some wear).
Old May 21, 2009 | 02:31 PM
Shirl's Avatar
Shirl
That's a good point. I also run the fronts with a little "less" air pressure.
Old May 21, 2009 | 05:48 PM
rebelheart's Avatar
rebelheart
Thanks guys,this is pretty much what I had read!
Old May 26, 2009 | 11:36 PM
roysvett's Avatar
roysvett
i have the same issue with 315 35 17 all the way around on 17x11 up front and 17x12 they are CCW 3 piece race wheels as soon as i get on it the tcc comes on can i tune this out in hp tuner in the tire size calculator
To New tires/traction control
