Does 16" fitt z06
Old May 21, 2009 | 02:08 PM
baezi z06's Avatar
baezi z06
Default Does 16" fitt z06
Hi
Does 16 inch wheels fitt on Z06 c5, rear
thinking og 16" drag tires .....
Old May 21, 2009 | 03:51 PM
NOLA's Avatar
NOLA
yes they fit with some minor grinding. I have 16x8 trans am wheels on et streets 26x11.50
Old May 21, 2009 | 05:31 PM
Dave1998's Avatar
Dave1998
Yes,
You should post in Drag Racing Section.
Most all c5s there are running 16 CCW drag pack on rear
Old Jun 23, 2009 | 02:34 PM
baezi z06's Avatar
baezi z06
Originally Posted by Dave1998
Yes,
i found wheels 16 x 9,5 that one here used on c4 vette rear..., and he said it was enough room left, is there much diffrence between rear brake size on c4 and c5?
kv Baering
Old Jun 23, 2009 | 03:23 PM
The Void's Avatar
The Void
kv Baering
I had to mount a 16" camaro wheel on the rear once when I got a flat. There was interference and the car would not roll. It is not the brakes that are the problem. It is the top of the spindle that sticks out the most. I probably could have used them if I could have clearanced the inside of the rim. They were not my wheels and it was only so I could get my flat fixed anyway so I didn't try. Good luck.
Old Jun 23, 2009 | 03:50 PM
baezi z06's Avatar
baezi z06
how much does it need to be, so it would have fitted?
kv baering
To Does 16" fitt z06
