Driver side door/ window stopped working???
Old May 21, 2009 | 09:52 PM
buoniconti81's Avatar
buoniconti81
Default Driver side door/ window stopped working???
All of a sudden a few minutes ago my window and lock on the driver side door isnt working... I also hear the relay in the passsenger side kick panel for passenger side window/ lock but hear no relay for the driver side... where is the relay at??? thanks
Old May 21, 2009 | 09:58 PM
TEXHAWK0's Avatar
TEXHAWK0
IF you cannot hear the relay click, you may have lost power to the door control module. Is it just the window that does not work, or are the door locks, etc. also not working?
You might have a short in the wiring in the rubber boot between the body and the door. You might move the wiring around and see if it starts working.
The relays are in the door control module that is toward the rear of the door from the speaker on each side.
Old May 21, 2009 | 10:25 PM
buoniconti81
I lost power to the whole door.... Is there a relay somewhere else to power the driver side door?
To Driver side door/ window stopped working???
