fender
Old May 21, 2009 | 11:46 PM
cobra3's Avatar
cobra3
Default fender
How much of a job is it to remove the right front fender on a 02 coupe. The owner before me had a leaking battery and the frame rail is rusted so I need to remove the fender and the computer so I can clean and repaint the frame rail. Do I need to remove the bumper first or can I get it off without taken off the bumper.
thanks for the help
Old May 22, 2009 | 12:19 AM
byronhunter's Avatar
byronhunter
This help??
Fender Replacement - Front
Removal Procedure
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the wheelhouse filler panel.
Remove the rear inner panel.
Remove the fender opening to the wheelhouse bolt.
Remove the fender to the rocker panel bolt.
Remove the fender rear center flange to the hinge pillar bolt.
Remove the fascia front close-out panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers and Fascias.
Remove the bolts attaching the fascia to the skid bar.
Remove the headlamp housing. Refer to Headlamp Capsule Replacement in Lighting Systems.
Lower the vehicle.
Remove the fender to the wheelhouse upper front flange bolts.
Remove the fascia to the fender reinforcement studs nuts.
Remove the fender to the upper hinge pillar fender bracket bolt.
Remove the fender to the upper wheelhouse flange screws.
Remove the fender.
