Lowering Question,,.,.,.,.,.,.,
Old May 22, 2009 | 10:08 PM
SharpCrease's Avatar
SharpCrease
Default Lowering Question,,.,.,.,.,.,.,
I notice alot of people on here lower there c5 on stock bolts but i went to the big auction site and saw a set of eibach pro-kit lowering springs and was wondering is it worth it. Should i just lower the vette on stock springs or spend the extra loot to lower it.
Old May 22, 2009 | 10:44 PM
txFRC's Avatar
txFRC
In my opinion this would be the best route to go, depending on your budget:
cheapest to most expensive.
1. lowering on stock bolts or aftermarket bolts
2. lowering on above + revalved shocks
3. coilovers
coilovers are the *best* and will set you back 1700$ roughly + install.
revalved shocks are around 5-600 i think? and lowering bolts are around 40$ front and rears.
Old May 22, 2009 | 11:18 PM
SharpCrease
Ok. Think i'll go the eibach kit with aftermarket bolts... thanx
Old May 23, 2009 | 12:20 AM
txFRC's Avatar
txFRC
i dont know where there is any 'coil spring' you can replace without going to coilovers. vettes use a horizontal leaf spring setup. and when you go to coilovers the 'spring' is around the shock body itself and you remove the leafs.
so i dont know why eibach would make a traditional lowering spring like you would put on an fbody or anything.
in my opinion, and what i am doing, i would reccommend getting the aftermarket bolts and lowering it to suit. then taking the plunge for a coilover setup down the road.
keep in mind you'll need to get it re-aligned. which should run you close to 150$.
are you going to do it yourself?
Old May 23, 2009 | 09:37 PM
SharpCrease
Ok. I don't have the money for coilovers but I can do the aftermarket bolts for now. Do I need to buy bolts for front and rear?
Old May 23, 2009 | 10:00 PM
txFRC's Avatar
txFRC
it depends on how low you want to go.
i saw a guy with a silver z06 post pictures of stock height/lowered on stock bolts/lowered on aftermarket bolts. should be findable with a search.
if youve got alot of speedbumps, driveways, ect in your area its something to consider on how low you go. i'd also get some front frame rolllers and side rails to protect against new ride height.
Old May 24, 2009 | 01:38 AM
ljthe2nd's Avatar
ljthe2nd
That Eibach kit that they sell on eBay looks like its some kind of springs, but its just an overpriced set of lowering bolts. Just ask the seller and you'll find out its just bolts and bushings.
Old May 24, 2009 | 02:31 AM
Quick Shot xMLx's Avatar
Quick Shot xMLx
Just lower it with the bolts. I lowered mine on stock bolts(said to be 3/4" front, 1" back) and it definitely looks better. These cars have a ridiculous wheel-fender gap which sucks because the actual car sits low(front air damn is about 2 inches off the ground, no real problems with clearance though).
Old May 24, 2009 | 12:06 PM
SharpCrease
Thanks for the suggestions guys. What vendor on here or elsewhere has the best deal on lowering kits(aftermarket bolts, bushing,etc).
Old May 24, 2009 | 12:55 PM
turbocrazy's Avatar
turbocrazy
Zip Corvettes
Also a supporting vendor $40
Old May 24, 2009 | 01:00 PM
SharpCrease
Good looking out.. what do i get for $40 from Zip Corvette
Old May 24, 2009 | 01:05 PM
turbocrazy's Avatar
turbocrazy
See for yourself. http://www.zip-corvette.com/Zip/prod...92FA590DE6E9C5
Old May 24, 2009 | 02:24 PM
j84buick's Avatar
j84buick
Remove the front bolts or cut the bushings = $0. Same result as the C6 lowering bolts.
Buy longer bolts for the rear (7x1/2 grade 8 bolts + washers & nuts) = $8 from a bolt shop.
Easy way to save some $$$$.
Old May 24, 2009 | 08:33 PM
TwoValveKid's Avatar
TwoValveKid
Get an alignment afterwords when adjusting stockers?
Old May 24, 2009 | 08:39 PM
lionelhutz's Avatar
lionelhutz
What he said. I put C6 bolts in the front of mine but only because the origionals had been seized and were chewed up really bad by the previous owner.
Peter
Old May 24, 2009 | 09:06 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I would love to lower mine, but it already drags on everything as it is. Maybe my front spring is worn out?
Old May 24, 2009 | 10:01 PM
Calgary's Avatar
Calgary
Cut the front bolts out all together.... Free
Take the back bolts and turn them all the possible way so that no threads are showing, and then weld over the top of the nut so it doesn't turn off..... Free
Take the front air dams (3 pieces) off the car and cut about 3/4 of an inch off of them with a table saw..... Free
You will have the lowest Corvette around and hardly scrape on anything. I've had mine that way for over a year (on bumpy Canadian roads) and the only place I ever touch is on the rad brackets as I climb the curb to my driveway.
This will work, and wont cost you a cent!!
g
P.S. My picture is from before I lowered it.
Old May 25, 2009 | 01:03 AM
letsgofast's Avatar
letsgofast
I took my C5 all the way down on stock bolts. It's as far as I would be comfortable dropping the car. I have a tricky driveway and have dragged on speed bumps with it this low.
To Lowering Question,,.,.,.,.,.,.,
