Intake removal w/o draining coolant?
Old May 23, 2009 | 11:14 AM
Tigger's Avatar
Tigger
Default Intake removal w/o draining coolant?
Can the intake be removed without draining the coolant? Is there enough room to leave the throttle body in place and still get the intake off? The service manual says to drain. I need to replace my oil pressure sender ( yes I have gone through nearly every page of the sticky, so I know there are other options ).
Old May 23, 2009 | 12:37 PM
Tigger's Avatar
Tigger
Anyone?
Old May 23, 2009 | 01:27 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you'll loose a bit, use a bolt or golf tee in the hose
leave the TB on the intake, vacuum the crud before removal, best to keep the dirt out of the intake ports
Old May 23, 2009 | 02:09 PM
Tigger's Avatar
Tigger
Pull & Plug !!! Great idea. I thought about using a clip to pinch the hose, but that might do damage.
Old May 23, 2009 | 02:47 PM
SteveDoten's Avatar
SteveDoten
the forum works
Old May 23, 2009 | 04:35 PM
mickey_7106's Avatar
mickey_7106
good time for the bypass mod
Old May 23, 2009 | 04:45 PM
SteveDoten's Avatar
SteveDoten
true, makes the process easier in the future
Old May 23, 2009 | 05:02 PM
Tigger's Avatar
Tigger
I'll check into it. Thanks.
To Intake removal w/o draining coolant?
