Brake Work
Old May 23, 2009 | 05:50 PM
T_Terrazo's Avatar
T_Terrazo
Default Brake Work
I know this might be dumb, but I've never worked on it before. How hard is it going to be for me to replace my own brakes? I read several threads about different options for rotors and pads. What parts and tools will I need in order to remove the original brakes and replace. Sorry, never done a brake job. Any help would be most appreciated.
Tyler
Old May 23, 2009 | 06:27 PM
Purerock105's Avatar
Purerock105
Are you replacing the pads only, or the rotors too...?
Old May 23, 2009 | 08:51 PM
T_Terrazo's Avatar
T_Terrazo
I need to replace the rotors and pads. I'm getting the shuttering feeling on the brakes.
Old May 23, 2009 | 09:53 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
It's really not that hard. You will need a large breaker bar to remove the bracket mounting bolts. THey are set to 125 ft lbs. And you need a torque wrench for the installation of the bracket and caliper. The caliper is torqued to 31 ft lbs.
Old May 23, 2009 | 10:00 PM
VetteFTW's Avatar
VetteFTW
well be careful with the rear ones, because I did mine today and the parking brake came off with the rotor, so now the retaining spring inside it is being a PITA to put back in correctly. I'll have to try again tomorrow..
Old May 23, 2009 | 10:04 PM
spider94r's Avatar
spider94r
I know the Hanes manuals kind of stink but in your case, with no prior experience, it might be worth spending $20 on a manual, just to get you through the basics. There's nothing too difficult about it but brakes are pretty important and you don't want to screw it up.
Old May 24, 2009 | 09:04 AM
RSchleder's Avatar
RSchleder
A buddy and I just replaced my rotors and pads. He has done many brake jobs and stated that the Vette brakes were very easy to do. My rotors simply came off without any pressure required even with 66k miles. I will say it was great to have someone with experience helping me due to the old saying "the devil is in the details". Using the caliber grease on the slide pins in the correct amount is important, as well as snapping the rear brake pads in is a bit tricky. I wouldn't do my brakes the 1st time without a experienced friend or some good instructions.
Old May 24, 2009 | 03:26 PM
T_Terrazo's Avatar
T_Terrazo
I have the 2002 GM Manual for the Vette for instructions, but have no one with experience which is sad. I called to ask some local shops how much it would cost to have them do it and they were going to charge $500 for the labor. Thereby, I decided that I would try this myself. I figured it couldn't be too bad. Any pointers would be appreciated. The GM guide is good, but I'm not sure if there is any difference between the 2002 and 2004 (I'm guessing not).
Old May 24, 2009 | 09:24 PM
fnsblum's Avatar
fnsblum
Good advice RS. Later! Frank
To Brake Work
