Rear brake change AAHHHHH!!!
Old May 23, 2009 | 07:33 PM
VetteFTW's Avatar
VetteFTW
Default Rear brake change AAHHHHH!!!
Ok so I was having a hard time getting my rear rotor to come off, and it came then this other thing was there and it has a spring, anyway I couldn't figure out what it was, but I think its the parking brake, how the heck do I put it back right??? No, the brake wasn't on...
Old May 23, 2009 | 08:12 PM
byronhunter's Avatar
byronhunter
This might help!
Old May 23, 2009 | 09:45 PM
VetteFTW's Avatar
VetteFTW
well i put it back together without that little spring because I just can't get it back in for the life of me, now I am going to fix it...but how do I do that???? THis is really really frustrating me! Also, how do I know it won't just happen on the other side too? Anyway, I did put the rotor and pads on, so now 3 of my 4 are changed, but this thing is a nightmare.
Old May 23, 2009 | 09:58 PM
VetteFTW's Avatar
VetteFTW
Originally Posted by byronhunter
This might help!
How does this thing even work? is that some sort of piston that pushes up? and how important is the little spring in there? (the angled wirey thingy)
Old May 23, 2009 | 10:04 PM
jrprich's Avatar
jrprich
Been there, done that
Take a look at http://forums.corvetteforum.com/c5-t...er-spring.html
post #4 & 7
Old May 23, 2009 | 10:10 PM
jrprich's Avatar
jrprich
The spring is important as it centers and holds the shoes in place. If those shoes get out of alignment while the wheel is moving you may have that wheel lock up
Old May 23, 2009 | 10:55 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I went through the same thing 5 years ago. I ended up leaving all that crap off the hub, and never looked back...I never use the P brake so no great loss.
Old May 23, 2009 | 11:01 PM
VetteFTW's Avatar
VetteFTW
does this mean it was too tight also? The ebrake wasn't even engaged and u can't turn the rotor freely...
Old May 24, 2009 | 05:37 PM
VetteFTW's Avatar
VetteFTW
well i made the "tool" out of a new craftsman screw driver I bought for this purpose, used a dremel to make the notch and slipped it over to the desired spot, used the "tool" and in less than 2 minutes I had it fixed. Put it all back together, torqued to spec of course, and went to the other side (drivers) and the rotor came off with no problem. Went and checked to be sure the brakes are ok, and no noise, no heat, no problems, mission accomplished! Thanks corvetteforum again!
Old May 24, 2009 | 06:37 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I like this guys way of thinking..
ericdwong's Avatar
ericdwong
Sounds good. I too went through the same thing when I first got my car. I've gotten good at putting that spring back in place now
Old May 24, 2009 | 07:59 PM
$$$frumnuttin'
thanks...too bad it took me 5 hours of grief to finally give in to the idea
Old May 26, 2009 | 10:21 AM
bighank's Avatar
bighank
Default I used a spring hook thru the EXTRA HOLE in the hub to get it on
After fighting 2 days to ALMOST get the spring on I used a spring hook
(tool with a curved end that can grab the spring) and went thru the extra hole in the hub after hooking one side and ALMOST hooking the other side. Before you do this adjust the starwheels on the parking brake so it just touches the inside drum surface on the rear rotor.
Did both sides like this and NOW my PARKING BRAKE will actually STOP THE CAR. Dealer said all the parking brakes are like mine. BS!!!!!!!
Just didn't want to pull the rear rotors off and adjust the starwheels/.
BIGHANK
To Rear brake change AAHHHHH!!!
