extending O2 sensors
Old May 26, 2009 | 12:44 AM
chevylad's Avatar
chevylad
Default extending O2 sensors
Anybody solder the front O2 sensor wire? Is it stainless? It doesn't seem to want to take the solder. I can always crimp, but I can always pull those apart. Soldering is just so much stronger.
Old May 26, 2009 | 01:38 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
it's too late now but I would of got some extensions. Cutting the wires can lead to problems with water and dirt getting in the connections. i guess now you best bet is to just crimp them and try to make sure they are sealed water tight.
Old May 26, 2009 | 01:51 PM
chevylad's Avatar
chevylad
You can get a sealing type heat shrink and it moves the connectors away from the exhaust heat so it shouldn't be an issue. I couldn't find anybody who sold the front extensions only the back ones.
I'm going to try soldering with additional flux tonight and see if it works.
Old May 30, 2009 | 04:01 PM
squidwards vert's Avatar
squidwards vert
Just crimp them and tape them up, you'll be fine. Did it myself three years ago, no problems.
To extending O2 sensors
