ignition problems 2127 code in bcm
Old May 26, 2009 | 04:58 PM
infintech's Avatar
infintech
Cruising
Default ignition problems 2127 code in bcm
i was wondering if any body had wiring diagram of the igintion switch and what wire to check the resistants so i can add a resistors to bypass the ignition switch i have a 2127 code
