Left Wheel Sensor Lockation
Old May 26, 2009 | 09:41 PM
Lakesvette's Avatar
Lakesvette
Default Left Wheel Sensor Lockation
I am getting code c1234 I had the ABS modual off and ready to sent to the fixer but the a post came up about running the pump so I did and it ran fine. I then put the modual back on and the c1234 will not clear. I know to clean the grounds and that is soon to happen as I am off to the power tour next week. But I want to trace the sensor back to check its connections too. I assume it will be found on the hub but is it the only wires there? Is it easy to remove?
Old May 27, 2009 | 08:23 AM
Lakesvette's Avatar
Lakesvette
Will search grounds today.
Old May 28, 2009 | 04:37 AM
cliff_ford's Avatar
cliff_ford
The sensor is in the hub and there is only one harness, which is easily removed.
To Left Wheel Sensor Lockation
