ATI----- DO IT YOURSELF?
Old Feb 7, 2002 | 01:41 AM
aces's Avatar
aces
Default ATI----- DO IT YOURSELF?
have they come up with a way to key the crank? any special electrical tools needed? seems like a day job (long day but that's OK) Will a stock A4 handle the power? Will the drive shafts handle the power?
[Modified by aces, 9:52 PM 2/6/2002]
Old Feb 7, 2002 | 09:27 PM
aces's Avatar
aces
Default Re: ATI----- DO IT YOURSELF? (aces)
TTT
Old Feb 7, 2002 | 09:40 PM
intel55's Avatar
intel55
they "say" you don't need to key the crank. I would however. Have to take the crank out. PTI has a way to do it with the crank still in there, but they are mum on any detail :rolleyes: I betit has been done before....
bunch of f=body guy have another way to do it with cutting the wasjer down... go to ls1tech and look for blackbird t/a (sp?)...
A4 will handle it , but not for to long.
Shafts will handle it. :cheers:
Old Feb 7, 2002 | 11:09 PM
boblackhardtop's Avatar
boblackhardtop
Just ordered my kit thru a race shop in overlandpark, KS where ATI is located.
In fact that's where ATI did their dynoing of the kit. I was told ATI had found a co. that will keyway the crank. They will soon offer it as an option on their kit & those that already have theirs installed can also get it done.
Hope it's not just hogwash!... They told me after I ordered my kit though...so it couldn't have been just empty marketing scheme.
Old Feb 8, 2002 | 12:13 AM
Injected65's Avatar
Injected65
7th Gear
Default Re: ATI----- DO IT YOURSELF? (boblackhardtop)
The balancer should not need to be keyed to the crank as the Procharger system runs off of the factory accessory belt. Under load the 6 ib belt will start slipping before the balancer would slip. That being said, ATI Procharger is not going to offer this service but ATI balancers does offer a way to lock the balancer to the crank by way of dowel pins. I would contact them if you plan on adding an external blower drive (other supercharger systems maybe) or are going for extreme power levels.
Chris
Old Feb 8, 2002 | 01:05 AM
boblackhardtop
Default Re: ATI----- DO IT YOURSELF? (Injected65)
Welcome to the CF Chris. I guess I must have misunderstood what you were telling me the other day.
Got my headers, still don't know what I'm gonna use. :confused: LT belanger or Shorties ? I figure I'll have plenty of power w/ the SC & probably won't miss the diff. The important thing's I'll save $400- 500. Anybody, your 02 is appreciated.
Old Feb 8, 2002 | 01:11 AM
aces's Avatar
aces
Chris
I'd rather be safe than sorry.
Am I correct in stating that if the balancer slips the timing changes on a crank fired ignition?
Will the output shafts be able to handle the power also?
[Modified by aces, 9:14 PM 2/7/2002]
Old Feb 8, 2002 | 01:21 AM
Sir Sel's Avatar
Sir Sel
Is the crank trigger in the front or rear of the motor? Pics if possible would be appreciated.
Old Feb 8, 2002 | 09:08 PM
aces's Avatar
aces
Default Re: ATI----- DO IT YOURSELF? (Sir Sel)
I thought it was in the front but i may be wrong. gotta go look
Old Feb 9, 2002 | 01:08 AM
LTD's Avatar
LTD
This is going to sound horrible, but what does "key the crank" mean? I know this is probably like asking what are tires, but for some reason I don't know what the phrase refers to. An explanation would be greatly appreciated.
Old Feb 9, 2002 | 01:55 AM
aces's Avatar
aces
Default Re: ATI----- DO IT YOURSELF? (LTD)
most engines have a slot in the crankshaft and the harmonic balancer that hold a "key"
the key fits in both slots
this keeps the balancer from turning on the crank
Old Feb 9, 2002 | 02:39 AM
Injected65's Avatar
Injected65
7th Gear
No problem man. Which ever header is fine :)
As for the keying of the crank, from what I have found out the ATI (balancer ppl) have come up with a way of drilling a hole partially in the crank and partially in the pulley and then you tap a dowell pin in place to lock the two from moving. Pardon me if I am not totally accurate in my decription as I have yet to see one in person. The main advantage to this is the crank does not have to come out of the motor!
Later,
Chris
Old Feb 9, 2002 | 05:41 PM
aces's Avatar
aces
I can see doing this. Sounds easy . Do you need a 90 degree drill or will a reg drill clear?
Old Feb 10, 2002 | 11:12 PM
aces's Avatar
aces
TTT :D
To ATI----- DO IT YOURSELF?
