P0654 h c (engine output speed circuit) help
Old May 30, 2009 | 08:20 PM
pdd000's Avatar
pdd000
Default P0654 h c (engine output speed circuit) help
my tach hasnt worked for a while. every now and then when i hit a bump itll work for a few minutes then die. so after i pulled the code p0654, i been searching high and low for problems(i pulled the ipc and checked for loose conections-looked for cut wires,etc). after all my searching i came to the conclusion i need a new pcm(from various web sites). my car has heads, cam, intake, tuned, the whole nine yards. so my question is do i just take it to a gm dealer to swap out the pcm . if i do that, itll have a stock tune and probably run like ****. or do i buy a new pcm and take it out myself and send it to my tuner,but doesnt the pcm have to sync'ed up by the dealer? thanks for the help
Old Jun 14, 2009 | 11:30 PM
pdd000's Avatar
pdd000
Ttt
