throwing a couple codes. help?
Old Jun 1, 2009 | 05:37 PM
99FRC Newb's Avatar
99FRC Newb
Default throwing a couple codes. help?
P1111 shows up constantly
Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P0113 sometimes
Intake Air Temperature Circuit High Input
and P0101 showed up once
Mass Air Flow (MAF) Circuit Range/Performance Problem
and i get the Active Handling Warming Up message @ start-up
the weather just warmed up a lot in the last couple weeks and its been sunny as hell
Old Jun 1, 2009 | 07:10 PM
99FRC Newb's Avatar
99FRC Newb
anyone?
Old Jun 1, 2009 | 10:04 PM
casey38boost's Avatar
casey38boost
Sounds like u might need a new IAT sensor, they are pretty cheap and easy to change.
U could also reseat both the IAT sensor and MAF sensor clip and check for any chaffed / loose wires.
Old Jun 1, 2009 | 11:40 PM
87SAM's Avatar
87SAM
http://www.gearchatter.com/viewforum41.php
To throwing a couple codes. help?
