A-pillar, single guage pod
Feb 7, 2002 | 05:32 PM
CI-3 Show Winner
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Does anyone make a guage pod that replaces the A-pillar piece but only has ONE pod in it???
I really don't need 2 gauges mounted.
TIA
Feb 7, 2002 | 05:37 PM
Re: A-pillar, single guage pod (mhefner)
There is one for the C4 but I'm not sure about the C5.
Feb 7, 2002 | 05:57 PM
Re: A-pillar, single guage pod (Cam Potter)
the only one I know of is the dual pod,
P.S. I have some in stock if you need.
Feb 7, 2002 | 09:12 PM
You can always use a seconds guage. Fuel pressure, Air/ Fuel, Boost, Nitous pressure, Transmission temp.. you get the idea..
Feb 7, 2002 | 11:09 PM
I'd check with AutoMeter directly.
Feb 7, 2002 | 11:36 PM
Re: A-pillar, single guage pod (vettewrench)
Hey Vettewrench, how much are they? I need one for Nitrous pressure and fuel pressure.
Thanks.
Feb 8, 2002 | 12:20 AM
Re: A-pillar, single guage pod (YellowManY2K+1)
Thanks.
They are 69.95 to your door I now have 2 left just let me know
630-820-7400
Thanks, Brian
Feb 8, 2002 | 01:18 AM
Does that price include gauges????
Feb 8, 2002 | 12:29 PM
No it does not but I can get you those gauges call me 630-820-7400
Feb 8, 2002 | 01:12 PM
CI-3 Show Winner
Cruise-In I Veteran
Cruise-In V Veteran
Re: A-pillar, single guage pod (ICULUKN-C5)
yes I'm aware of all the different gauges that I could use to monitor other things but I only want to monitor n2o pressure.
Checked autometer and they have plenty of single pod pillars for other cars, not the vette though.
Plus there is the added cost of having to put a 2nd gauge for something I don't really care to monitor...
Now if someone wants to give me a useful gauge, then I might go to a 2 gauge pod setup... :D
[Modified by mhefner, 11:12 AM 2/8/2002]
Feb 9, 2002 | 08:53 PM
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Is it possible to have a guage for the transmission temp?
Feb 9, 2002 | 09:51 PM
Re: A-pillar, single guage pod (Road_runner)
Check out
http://www.carrollsupercharging.com
I have a single gauge pod mounted on my A-pillar that they installed for my boost gauge. Looks like stock. I'm sure they'd be able to get one to you.
Feb 13, 2002 | 03:57 PM
CI-3 Show Winner
Cruise-In I Veteran
Cruise-In V Veteran
Re: A-pillar, single guage pod (QuickSilver97)
thanks quicksilver.
I called carrolsupercharging and they do make a single guage pod A-pillar and it only cost $20! My is going out tomorrow.
thanks
Feb 13, 2002 | 04:01 PM
Great! Glad I could help!
Feb 13, 2002 | 04:04 PM
Fuel Pressure is important.
EGT can help you estimate A/F ratios, if you correlate to Wideband data across rpms from a dyno.
Feb 13, 2002 | 09:06 PM
You already have the transmission temp on the DIC. I'm sure it wouldent be too hard to tap into the wiring for that sensor and add another gauge for it. but why would you?
Feb 13, 2002 | 09:42 PM
CA Events Coordinator
How much for the Twin Pod, Fuel pressure & Boost gauges with the White face Gauge?
vetterdstr :chevy
