Help- what are torque spec for LS1 heads?
Old Jun 3, 2009 | 02:46 PM
Rdrcr's Avatar
Rdrcr
Cruising
Default Help- what are torque spec for LS1 heads?
I am rebuilding LS1 engine using head studs instead of bolts.
What arethe torque specs?
Thanks in advance
Old Jun 3, 2009 | 08:37 PM
Rdrcr's Avatar
Rdrcr
Cruising
I forgot to mentioned the head studs are ARP. I just need to know what torque value on the final pass or where I can get this information.
Old Jun 3, 2009 | 09:52 PM
geezel's Avatar
geezel
I believe ARP has that info on their website.
Old Jun 3, 2009 | 10:04 PM
vsocks1's Avatar
vsocks1
I used three passes on the large bolts using ARP Moly Lube 35-55-80 ft. lbs.
Once that sequence is complete I did the small ones in proper sequence to 22 ft. lbs.
Old Jun 4, 2009 | 05:05 PM
Rdrcr's Avatar
Rdrcr
Cruising
Are torque values the same for bolts vs studs?
Old Jun 4, 2009 | 05:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
vsocks1 is using ARP studs, so the tq values he posted are for the nuts...exactly what you are looking for.
The studs themselves get no torque...run them down till they bottom out, that's it. Do not try to tighten them beyond that, or you risk cracking the block.
Old Jun 4, 2009 | 05:34 PM
Rdrcr's Avatar
Rdrcr
Cruising
Thanks for all your help. That's exactly what I am looking for.
To Help- what are torque spec for LS1 heads?
