I've had my C5 for 3 years now. This is the first time I had this problem. All other gears are fine, but I can not get it into park. I would like to try and repair it myself. Any suggestions? All help would be greatly appreciated. Thanks
Two possibilities Ignition lock out cable and park solenoid
I had just the opposite problem. Refusing to come out of park. Unplugging the park soleniod wire under the shifter boot solves that problem.
When I disengaged the plastic tabs to raise the boot cover I also saw the cable which won't let you shift into park unless the ignition is turned OFF. If this cable is stuck or binding might be your problem.
I left my cable alone since it wasn't contributing to my problem.
Look on the current posts and see a diagram someone posted to show where the park solenoid is. If you disassemble the console and boot housing you will see both the ignition switch cable and the solenoid.
..................When I disengaged the plastic tabs to raise the boot cover I also saw the cable which won't let you shift into park unless the ignition is turned OFF. If this cable is stuck or binding might be your problem..........................
......BIGHANK
This is news to me.
A cable that won't allow the shifter into "Park" until AFTER the ignition switch (key) is turned to "Off"?
I always shift into park BEFORE turning off the ignition. Both of my C5's work this way as well as others that I've driven.
Misstated the ignition lockout...
You can t remove the KEY until the shifter goes into PARK. If this cable is stuck might be causing a problem. BIGHANK
