UD pulley belts???
Jun 6, 2009 | 09:56 PM
UD pulley belts???
what belts do i need for a ud pulley? anyone know the part numbers and i am guessing i should use gator belts?
Jun 6, 2009 | 10:09 PM
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Kinda depends on what balancer you have....10%, 25% UD? Is a/c pulley also UD or no?
Jun 6, 2009 | 10:19 PM
Quote:
Originally Posted by
Y2Kvert4me
god question!
i have no idea except its a asp ud pulley i believe
Jun 6, 2009 | 10:22 PM
St. Jude Donor '03
ASP is 25% ud on accessory belt, and 10% ud on a/c belt.
does it look like this?
Jun 6, 2009 | 10:40 PM
yea i guess it does . mine has a wider belt in the front or at least i guess the view you are showing me is the front and a smaller or thinner belt on the rear which is bigger than the front pulley if that makes sense
Jun 6, 2009 | 10:44 PM
i just took a pic of it give me a sec to upload it
Jun 6, 2009 | 10:45 PM
St. Jude Donor '03
Yes, the front accesory belt is a 6 rib, the a/c belt is a 4 rib.
If you do have an ASP, the Gatorback belt #s you will need are:
Accessory: 4060775
A/C: 4040410
Jun 6, 2009 | 10:48 PM
here are a couple pics of it
Jun 6, 2009 | 10:51 PM
St. Jude Donor '03
Yes, sure looks like an ASP.
See my above post for correct belt sizes.
Jun 6, 2009 | 10:54 PM
awesome bro thanx for the part #s
i am trying to get the last few little parts i need to get my h/c header stall and rear swap done! any idea where i can get the arp bolt for that as well as i hear it doesnt need to be torqued as hard as the gm bolt and easier to put in because its longer than the gm bolt as well as the belts
Jun 6, 2009 | 11:05 PM
St. Jude Donor '03
Jun 6, 2009 | 11:08 PM
bro you just ROCK!!!! thanx for the help
