Pull Key Wait 10 sec?
Old Feb 8, 2002 | 09:57 AM
TyVette01's Avatar
TyVette01
Default Pull Key Wait 10 sec?
Hello Folks,
My buddy has a 97 C5 and is recently getting "Pull Key Wait 10 sec" on the display. When he tries to drive off the car will just die. He said the codes that comes up is: LDCM U1064H and RDCM U1064H. (Loss of Communication with DCM). What does this mean? He also mentioned he installed a Column Lock Bypass about 1 year ago. :seeya
Old Feb 8, 2002 | 02:47 PM
TyVette01's Avatar
TyVette01
Default Re: Pull Key Wait 10 sec? (TyVette01)
Anyone know :seeya
Old Feb 8, 2002 | 02:55 PM
vette2001c5's Avatar
vette2001c5
The "pull key" message sometimes it occurs when the resistor pellet in the key is damaged or dirty. You might tell your friend to try using another key and see if the problem goes away.
Old Feb 8, 2002 | 03:57 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
It just mean his PCM has loss communication with the system. He has nothing to worry about since he has the C/L bypass!
To Pull Key Wait 10 sec?
