99 emergency brake question
Old Jun 7, 2009 | 02:17 PM
missedherbill's Avatar
missedherbill
Default 99 emergency brake question
Mine works fine most of the time when I try to move the car in reverse. Doesn't work at all when in a forward gear. Anyone else had this issue?
Old Jun 7, 2009 | 04:16 PM
huttler's Avatar
huttler
The e-brake is just "good enough" to keep the car from rolling (most of the time). It won't prevent the car from moving if you have it in gear.
I usually have to pull and release my e-brake 2-3 time before it will hold.
I haven't heard about a fix for this
Old Jun 8, 2009 | 11:52 AM
bighank's Avatar
bighank
Default Wrong! Dealer said its a PARKING BRAKE and they are all like that BS
I drove my 98 for about 3 years with the parking brake inoperative.
Then did a brake job. If you pull the rear rotors and adjust the starwheels on each side so that the rotor JUST DRAGS A LITTLE when sliding it over the parking brake shoe you will have parking brakes that will STOP THE CAR DEAD. The self adjusting mechanism is crap.
Pull your rear rotors, replace pads if necessary, paint the calipers red like a Z06 and you are good to go.
BIGHANK
Old Jun 8, 2009 | 12:30 PM
wcsinx's Avatar
wcsinx
The fix is to take off the rear rotor and properly adjust the p-brake. My p-brake holds my car rock solid now. In fact, I stalled my car this morning because I left it on and tried to idle out of my garage in reverse as usual.
wcsinx's Avatar
wcsinx
There is no self adjusting mechanism.
Old Jun 8, 2009 | 08:22 PM
bighank's Avatar
bighank
Default According to GM applying the P B when in REVERSE adjusts the PB
I have never found this to work but thats what GM says.BIGHANK
Old Jun 8, 2009 | 08:30 PM
Nick1's Avatar
Nick1
The poor action of the parking brake is really annoying! I have seen many posts on this and tackled the issue when I bought my 04C5 a couple of years ago. I did the complete disassembly, cleaning and adjusting. Overall it turned out pretty good and much better than it was, but not that real skidding type of "ricer" e-brake. Maybe I expect too much.
Old Jun 9, 2009 | 09:14 AM
wcsinx's Avatar
wcsinx
Can you show me the GM documentation stating that the parking brake for a c5 Corvette is self adjusting? There is some self adjustment on the cable tension, but not the brakes themselves.
With a typical drum brake system, there's a pawl that kicks over the starwheel. There's nothing in the C5's p-brake that's going to do this.
Old Jun 9, 2009 | 11:18 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
BIGHANK
I agree totally. Adjust these the old school method and it'll work just fine. I went without mine for years and the dealer saying it was normal....not true. Old school works here.
Old Jun 9, 2009 | 12:37 PM
wcsinx's Avatar
wcsinx
Don't buy into that b.s. I heard the same thing that, "C5's just have weak parking brakes." Once they're adjusted correctly, they will hold your car very firmly.
To 99 emergency brake question
