I have a K & N intake on my 2004. I heard you can get more air into it by taking off the plastic panel covering the radiator. Is this a good idea or no? I have bought the z06 front air inlets but I still hear you can get more air in there by doing this to that panel. Please let me know!!!
Is your radiator shroud not cut with the K&N brackets installed so that there is a 1" by 10" opening in the shroud now?
If it's not cut with brackets installed you should contact K&N and get the proper brackets to make the cut. Also if you really think you need more fresh airflow...just install the z06 grilles.
That's a no no. That plastic panel is the radiator shroud. It serves a very important function. It helps along with the spoiler that hangs down in the front of the car (the thing that always scrapes when you go over a speed bump) direct the air across the radiator to cool your engine. If you were to remove this your coolant temps for you engine would rise to undesirable temperatures.
I have the z06 grills. How big of an opening do I cut?
