HELP!! Tail Light Advice Needed
Old Jun 9, 2009 | 09:10 AM
drew47000000's Avatar
drew47000000
Default HELP!! Tail Light Advice Needed
For some reason my left rear turn signal lights are not functioning. What's weird is that they work perfectly fine when I push the hazard button but not at all when Im driving and need to make a left turn. The clicking noise on the inside does that rapid click click click noise and the front signal still lights up flashing faster than normal too. Does this sound like a bulb or fuse problem or something more complicated and complex. Either way I would sincerely appreciate any and all advice you could offer. Im not sure how to change the bulbs or fuses for this project either so if you think that it may be that I could definitely use some advice on how to properly service those. Thanks a million!
Old Jun 9, 2009 | 11:23 AM
ljthe2nd's Avatar
ljthe2nd
Did you check the tail light bulbs in the rear? Take a torx screwdriver. It's either a #10 or #15 and remove the tail lights and check the bulbs.
That hyper-flash, or faster than normal blinking, is an indication of a burned out bulb.
Old Jun 9, 2009 | 02:05 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If your hazzard switch is working correctly along with bulbs, more than likely it's the dreaded multifunction stalk switch that has gone bad.
I ended up doing this repair not long ago. I also had a bad hazard switch and rear wiring harness to boot.
Started with checking the bulbs, two screws and remove from the back of the light.
In your case, since the hazard lights are functioning correctly, it's probably the stalk switch. The contacts get burned and no longer provide enough current to power the bulb. In my case I was getting around 4 volts instead of 12 volts.
If you're somewhat handy it's not too bad of a job to replace.
Old Jun 10, 2009 | 12:35 AM
drew47000000
Update: so tonight I replaced the rear bulbs and was not successful in fixing my problem. Again the only thing that does not work is the left rear turn signal light flashing.It works for brakes an hazards just not when used as a left signal. Can anyone please help walk me through a troubleshooting list to help solve this. If anyone has some ideas I would love to try them. Thanks for taking the time to read and respond.
Andrew
Old Jun 10, 2009 | 01:24 AM
ljthe2nd's Avatar
ljthe2nd
Well in that case I've got to agree with ajg1915, it's probably the stalk switch.
Old Jun 10, 2009 | 06:50 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Andrew
Hey Andrew.
Pick youself up a cheap multimeter at you local auto store for $20.
Unplug the bulb from the turn signal switch. Take the black lead from the multimeter and hook it to a ground on the chassis. Flip on your turn signal and then take the red lead and touch it to the contact spot of the bulb socket and see how many volts you're getting.
I had the same problem, ended up being stalk switch. Not sure how handy you are with a wrench but you could swap out the stalk yourself.
I would buy a new stalk, not a used one.
Tony
Old Jun 10, 2009 | 06:20 PM
drew47000000
hm sounds like theres a fair chance it's the stalk switch but I have no idea what a stalk switch is or how to replace it. Also where to buy it. Thanks for your continued responses!
Old Jun 10, 2009 | 09:09 PM
byronhunter's Avatar
byronhunter
Contacts in the multifunction switch are bad in your case. Not uncommon. (The multifunction switch is the signal light arm/headlamp switch.)
Old Jun 11, 2009 | 10:19 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Send me your email address and I'll send you a how to pdf file.
Tony
ajg5@aol.com
Old Jun 12, 2009 | 11:45 PM
drew47000000
Sent you a PM. Thanks! If anyone else has any good ideas or thoughts, I'd love to hear em'!
To HELP!! Tail Light Advice Needed
