Odd Problem
Old Jun 9, 2009 | 03:37 PM
HarryO's Avatar
HarryO
Default Odd Problem
It was about 78 degrees outside and i was sitting at a light. when i looked at the Ext temp readout it said it was 47 degrees. After i started driving again i shut off the AC and the reading returned to normal. after i turned the AC back on it seemed to work fine? Any thoughts
Old Jun 9, 2009 | 04:18 PM
poolboy's Avatar
poolboy
I would say you either have dirty connections at the outside air temp sensor, or the sensor is going bad. The sensor is up under the front end on the passenger's side.
