Tie rod end adjusting/jam nuts
Old Jun 11, 2009 | 04:57 PM
C5_Z06's Avatar
C5_Z06
Default Tie rod end adjusting/jam nuts
What size is the jam nut on the tie rod ends? 22mm wrench? I need to buy the correct size wrench to open the nut before I can adjust the toe.
When trying to open the jam nut the rod end moves and then stops at the end of it's stroke (obviousely). Is it then ok to continue to apply the needed force to break the jam nut loose (using the tie rod end itself as a stop) or do I need to hold the rod with another wrench?
Old Jun 12, 2009 | 02:25 AM
C5_Z06's Avatar
C5_Z06
Anybody know the size of the jam nut?
Old Jun 12, 2009 | 06:46 AM
rws.1's Avatar
rws.1
I believe it is 22. I used a 7/8 inch... which is 22.2 mm.
Ideally you should use 2 wrenches.
Old Jun 12, 2009 | 08:21 AM
C5_Z06's Avatar
C5_Z06
Thanks! Off to buy a 22mm wrench then.
To Tie rod end adjusting/jam nuts
