Dyno help
Old Jun 11, 2009 | 07:23 PM
Mastertz's Avatar
Mastertz
Default Dyno help
So today i was at the Dyno an to start i was running Lean, so we went into my Predator an went +4% an we went from 14/1 to 16. so since he's seen this before we went to -4% an then we went to 17 almost 18. I called Diablo an they said it was the car but it was running fine. im going to clean the fuel injectors tonight an hope that helps. If not im not sure why its running lean. we never even got to open the car all the way up we got to 4400rpm's before he stopped cause its running so lean.
Old Jun 11, 2009 | 08:59 PM
VinnyT's Avatar
VinnyT
I would also clean the MAF sensor. Do you have any cold air intake? Is the air filter clean?
