speed sensor
Old Jun 14, 2009 | 09:12 AM
optimum01's Avatar
optimum01
Default speed sensor
OK-I have code tcs1232H- left front speed sensor.Very annoying-the constant flashing on the dash-abs then service TC-clear it-hit a bump and it starts all over again.I was told on the forum that the actual speed sensor rarely goes bad-that its probably the harness or harness connections.Should I just have the whole thing replaced and be done with it?Do they just sell the connection/harness part alone-I dont think so,what have you done?01 coupe.
Old Jun 14, 2009 | 09:27 AM
cliff_ford's Avatar
cliff_ford
You can get the harness and the connectors, with a pig-tail. The female connectors are prone to getting squashed making a poor contact with the male pins.
