New LSX Shortblock... advice?
Old Jun 14, 2009 | 02:08 PM
Tkenmore's Avatar
Tkenmore
Default New LSX Shortblock... advice?
Hey everyone, i am purchasing a 99 WS6 6 spd that needs a motor. I REALLY want around 400hp before power adders. How does this package from Schwankes Shortblocks sound:
· GM 5.3L Truck Cast Iron Block (Bore 3.903)
· 3.622” Stroke GM Crankshaft
· 6.098 LS1 Connecting Rods
· Forged Flat Top Pistons
· 1.5mm Power Pack Ring Set
· ACL Rod & Main Bearings
· ARP Rod Bolts
· Digitally Balanced Assembly
· Fully Assembled & Blue Printed
I was thinking of going with an LS6 top end with perhaps a different cam. Would this be a good setup for a street car, that could potentially handle some boost or juice?
I figured the iron block and the forged pistons would absolutely lend themselves to a bit more oomph down the road, but i really want 400hp without.
Thanks fellers.
Old Jun 14, 2009 | 03:38 PM
TurboBerserker's Avatar
TurboBerserker
IMO you are better off with a 6.0L block -- either an LQ4, LQ9, LS2, etc., even a stocker.
Old Jun 14, 2009 | 08:13 PM
ArKay99's Avatar
ArKay99
Put an LS6 top end on this and you'll be north of 400hp imho. Lingenfelter short block and you'll be in good shape to put your choice of power adder on.
Old Jun 14, 2009 | 09:51 PM
blue63cpe's Avatar
blue63cpe
Thats a 346.50 ci., look in to the world products warhawks. they will work on that bore. Pick a good cam and well over 400hp is in reach, and Turbo have you ever looked for a 6.0 or a 6.2? And when you find them the price is high and the ls2 or 3 is stupid high for a used engine.
Old Jun 14, 2009 | 09:58 PM
Tkenmore's Avatar
Tkenmore
The price for this set up is $1699. really good value for the dollar. That lingenfelter shortblock is really nice, but lots more money. Paying for the name i guess. Blue63cp is right, those motors are still really in demand and pricey. Not too many years ago 346ci was in all the Vettes lol.
Is that a good bottom end for nitrous or in a turbo application?
Old Jun 14, 2009 | 10:12 PM
blue63cpe's Avatar
blue63cpe
The iron block is way stronger than the aluminium,Its the same 6 bolt main as all ls- engines. Your cr is ok for nitrous but to high for a turbo. Go slow with the mods ,good heads and cam will scare the begeepers out of you. By the way the block is only 88 lbs more than the ls1-2-3.
Old Jun 14, 2009 | 10:22 PM
Tkenmore's Avatar
Tkenmore
i figured the cr was too high in a boosted application, nitrous was more what i was interested in anyway. Never used it, this is a budget toy for a guy with a budding family lol. What heads/cam would you suggest? We found a really nice set of LS6 heads that i thought would be a nice mild set up, but they are still pricey. Any advice? Streetability is a huge factor for me, as i would like my wife to be able to drive the car as well. M6 btw.
Old Jun 14, 2009 | 10:24 PM
TurboBerserker
I see LQ4s for sale all the time. Prices are ussually < $1000 for a short block (and sometimes for a long block) on other IB-owned sister sites.
I have an LS2 and an LQ9 block in my garage .
Here's a *complete* LQ4 for $1800 (IB-owned site) http://www.performancetrucks.net/for...&highlight=LQ4
High mile LQ4 long block - $800
That took under 3 minutes to find. There are 4 LQ4s on the auction site for $700-1200.
These blocks are plentiful.
LQ9s and LS2s take more work but are findable with a little patience. I've seen LQ9 short blocks sell for $700 and long blocks for $1300.
LS3s, I agree.
Old Jun 14, 2009 | 10:50 PM
blue63cpe's Avatar
blue63cpe
All genIII/IV parts are expensive,complete heads will run $1800 to 3K. Cams cost more, and then rockers, stock to aftermarket are more costly than stamped steel. Streetability--ouch, that is subjective everyone is different. Sounds like you picked up 'the free cat' and it's clawing at your wallet. Do you have a clutch?
Old Jun 14, 2009 | 10:56 PM
Tkenmore's Avatar
Tkenmore
A clutch is in the works as well, currently it's a newer stocker ls1. the current owner (and good friend of mine) just informed me that he found a good deal on a set of LS2 heads and an LS6 cam. He also bought some hardened pushrods for a smokign deal. We have about $3500 to work with for everything.
That swankes combo with a set of LS2 heads and an LS6 cam should run about 365ish crank hp? or am i off base? with an LS6 intake maybe a bit more. Then a 125 shot puts me close to the 500hp threshold. Which would make a nice cruiser and something i could take on trips without worrying about too much. Or am i off base? The car is in California, i am in Canada. IF i fly down there and decide i don't want it, he wants to make sure it's still smoggable if he keeps it.
Old Jun 14, 2009 | 11:05 PM
blue63cpe's Avatar
blue63cpe
turbo a drop in block should be under 60,000 miles. The first on your list was a deal, but the pm was sent in 40min all the others I looked at were cores 200 to 300 bucks at most. check the yards and see what they want for a low mi. 6.0/6.2 with ECM/TB/and acc if its a ls1/2/3 they think its gold. Just what I've been seeing.
Old Jun 15, 2009 | 12:29 AM
blue63cpe's Avatar
blue63cpe
Tkenmore , that combination is a iron block ls6 my z06 with headers is 370rwhp (fast enough for me) so yes with a 125 shot it would kickbutt. good luck with your new ws6.
Old Jun 15, 2009 | 08:46 AM
TurboBerserker
Definitely -- trying to get a complete drop in out of a salvage yard will run you some green. I'm just pointing out there are better options than the salvage yard. Plus, the OP is not buying a complete drop in motor, so you aren't really comparing apples to apples there on price.
Parts are the same between the 5.3 and the rest of the genIIIs -- $1700 for a 5.3L is relatively very expensive per HP -- you can buy stock 5.3 / 4.8 short blocks on the truck site all day long for < $500. A set of stock sizes forged flattops with rings should run around $400-600. On that note, a high mile LQ4 short block can easily be rebuilt for under $1000, and that brings you home at the same price as the 5.3, but with more potential, IMO. Then, again, I'd do the rebuilding myself which save some green, but costs time, and if the OP doesn't want to spend the time doing that, I can see where he's coming from.
You can buy a professionally built 370 (.030 6.0) with forged wiesco flattops, stock crank, callies rods and arp fasteners all around for $3300ish by the big Speed and Performance shop in Texas.
Old Jun 15, 2009 | 10:26 AM
Tkenmore's Avatar
Tkenmore
Thanks guys. I think we're gonna go with that 5.3 shortblock from Scwankes, and an LS6 top end. This will get me where i want to be power wise and the wife can still drive it. Toss in the juice for those special occasions and i'll have a great toy for well under 10k.
Thanks again.
Old Jun 15, 2009 | 08:46 PM
Tkenmore's Avatar
Tkenmore
I came across this today. Emailed about it. This would be a very fun motor to put into the car:
http://www.ls1tech.com/forums/lsx-pa...block-f-s.html
To New LSX Shortblock... advice?
