Gas gauge
Old Jun 14, 2009 | 08:28 PM
giwhop's Avatar
giwhop
Default Gas gauge
while driving the other day still had 3/4 tank of gas and gauge went to empty and low fuel light and check cauges light came on.Cleared code 10 pcm 1431 ac and gauge started working so i thought.But with gauge reading 1/4 tank car ran out of gas filled back up but gauge still acting up.
Old Jun 14, 2009 | 09:28 PM
hawk4077's Avatar
hawk4077
Sounds like a gas problem to me. I would fill it up with Chervon and add a can of sea foam that's what I've been useing in my 02 coupe have had no problems with the gas gauge.
Old Jun 14, 2009 | 09:56 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Common issue. I used techron and issue went away.
Old Jun 15, 2009 | 03:56 AM
DaZ06's Avatar
DaZ06
yea i had that same problem
i read it was some kind of corrocion build up or something but yeah good gas and an cleaner does the trick most of the time
Old Jun 15, 2009 | 11:41 AM
David426's Avatar
David426
you have sulfer deposits forming on the fuel sending units.. Techron is needed on a regular basis or you will eventually have to replace the sending units, which is not cheap
To Gas gauge
