Active Handling Codes
Old Jun 14, 2009 | 09:54 PM
TheBigDog's Avatar
TheBigDog
Default Active Handling Codes
I have had the 1232 and 1233 codes for some time. I just reset and go on. What is common between the front wheel speed sensors? I have checked all the grounds and they are in perfect condition. The only thing I have not done is pull apart the ground connectors that are attached to the frame behind the headlights and look for corrosion. Something is causing just the front to throw codes
Thanks,
The Big Dog
Old Jun 15, 2009 | 12:24 AM
87SAM's Avatar
87SAM
Have you checked the two front wheel speed sensor connections themselves?
Old Jun 16, 2009 | 01:20 AM
alaplaca's Avatar
alaplaca
3rd Gear
I am experiencing the same thing in my 03. any ideas?
To Active Handling Codes
