nero
Old Jun 14, 2009 | 10:13 PM
corvettenero's Avatar
corvettenero
6th Gear
Default Gas filter
hi how to replace gas filter on a 2002 c5
Old Jun 14, 2009 | 10:59 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
First you need a fuel filter tool...under $5 at most any auto parts store. Filter is located on the driver side rear on the frame rail. You need to relieve pressure from the line I just pulled the fuse for the fuel pump and cranked the car over since I didnt have any other way to do it.
From there you just disconnect the fuel lines from the filter I managed to get the front side off with the filter attached to the frame rail but ended up removing the mounting bracket to get the back side off. I suggest wrapping a rag around it as you will still get some leakage.
Installing the new filter is easy the lines just click in place.
Its not a bad job overall.
Old Jun 16, 2009 | 09:27 PM
corvettenero
6th Gear
Thank you for your help...
Gonna try probably this weekend.
To nero
